Searched..car still won't start
Ok, so I have searched and all the problems other people had didnt fix my problem. I have a 1992 civic with a Z6 swap in it..I drove the swap for 150 miles fine and then the clutch went out..I think I fixed that. Before I fixed it the car started just fine..about a week before I tried to start it this last time actually. All I did was change the Clutch master cylinder..nothing else. I have checked all my plugs, grounds, traced that small wire that goes into the starter and thats fine. Starter is fine. The car doesn't even want to crank, its just a click and then I hear the main relay whirring when I try to start it. I swapped out ECU's...still nothing. anything else left it could be?
alright dude...ill give you a list of things to check according to your situation...
1}check the battery terminals for corrosion or looseness
2}check the battery haha...
3}clutch is not completely depressed if you have a manual for your car is not in park if you have an auto...
4}broken loose or disconnected wiring in starting circuit
5} starter motor pinion jammed in flywheel ring gear
6}bad starter
7}ignition switch is faulty
8}starter pinion or flywheel teeth worn or broken...
check these out and let me know dude...seeeeeeeeeyaaaaa
6}bad starter
grounds are good..please do not tell me to check the grounds and fuses..trust me..I have done it a TON of times. It has something to do with the starter I am almost certain (but the starter is good I took it to get it tested)
the only thing I can't check is the ignition switch...now..as far as everything else its good..the battery has a full charge, I even switched out batteries with my step-bro and it still didn't start. Flywheel is fine (just had the tranny off so I inspected it lol) starter is good (I just reinstalled it before I made this topic)
well i diagnosed your problem using a haynes manual according to your description so you have to figure it out from there i dont know what else it could be both from personal experience and the manual...
