T braket prob. with b20 into EG. the braket doesn't reach
Old May 28, 2007 | 10:40 PM
mustang5.slow's Avatar
* B A N N E D *
Default T braket prob. with b20 into EG. the braket doesn't reach
ok so i just did my swap and the t braket i have allong with the mount came from a 2000 SI...buth when i bolt on both of the tranny holws. it is basically imposible to reach the mount. the top motor hole doesn't even line up at all...
**when i only bolt the lowest holw to the tranny it makes it to the mount...
how do the other guys moke it reach, or use it.
Old May 28, 2007 | 10:51 PM
Team RS2's Avatar
Default Re: T braket prob. with b20 into EG. the braket doesn't reach (mustang5.slow)
you usally have to work the motor back and forthe to get that bolt in
Old May 28, 2007 | 10:59 PM
* B A N N E D *
Default Re: T braket prob. with b20 into EG. the braket doesn't reach (Team RS2)
i too the oem hacks and pleased them to the motor and the frame and pushed it ...at first it looked good but then the side mounts reach the limit and didn't let the motor move any more at all.
Old May 28, 2007 | 11:08 PM
Team RS2's Avatar
umm try it again and undo he side mounts so it has a little bit more play, and it should work
Old May 28, 2007 | 11:14 PM
USDMCIVICHATCH's Avatar
um.. why are you trying to use a ek T bracket on a eg. You need to get yourself a 94-01 integra T bracket and you'll be good to go
Old May 28, 2007 | 11:23 PM
SiYouLater's Avatar
I believe you use a Integra rear bracket for b-series into eg.
Old May 28, 2007 | 11:36 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">um.. why are you trying to use a ek T bracket on a eg. You need to get yourself a 94-01 integra T bracket and you'll be good to go</TD></TR></TABLE>
thats right, and make sure its from a manual, not auto
Old May 28, 2007 | 11:53 PM
EkJavi's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">you usally have to work the motor back and forthe to get that bolt in </TD></TR></TABLE>
Old May 29, 2007 | 08:38 AM
* B A N N E D *
Default Re: T braket prob. with b20 into EG. the braket doesn't reach (EkJavi)
oh thanks guys I'll try an integra braket.
MIEj1
Feb 25, 2013 06:07 PM
mustang5.slow
14
May 26, 2007 11:22 PM
Jabinya
Apr 15, 2007 09:30 AM
allmotorh22
Nov 24, 2006 08:30 PM
