Hey guys, i dynoed my ride..
Old Jun 3, 2002 | 07:43 AM
b18tdelsol's Avatar
Default Hey guys, i dynoed my ride..
Dang, i really wanted to post the dyno graph, but i couldn't find someone with a scanner this morning. You think it would come out if i took a pic of it with my digital camera? Well anyways.. my final numbers after tuning was 210whp and 170lb of torque @ 7lbs psi. I hoping to get around 220, but i guess those are okay numbers
I'm currently running a revhard stage 2c kit, which is running a t3/t04e, on my delsol with a b18b. I have other minor mods such as:
skunk manifold
aem cam gears, pulleys, fpr.
crane ignition
exedy clutch/spoon flywheel
and a really restrictive exhaust. its like 2.5 dp to a high flow cat, then back down to 2.25 crush bent pipiing, to a greddy exhaust.
I wanna get 250 before we head to the track, what do guys think i should get to achieve that? I was planing on getting some turbo cams, and at the track, turn up the boost to 9lbs, and get a full 3in exhaust. for the delta gate, all i need to do is get a 9lb spring right? thanks guys.
Old Jun 3, 2002 | 08:33 AM
modvp's Avatar
Default Re: Hey guys, i dynoed my ride.. (b18tdelsol)
Those are really good #'s for your setup! Are you running stock injectors? Try a set of 310cc and an 8:1 FMU disk (6:1 may work too). Then turning up the boost to 10psi should net you very close to your 250 whp goal.
Old Jun 3, 2002 | 09:29 AM
b18tdelsol's Avatar
Default Re: Hey guys, i dynoed my ride.. (modvp)
yeah, im running stock injectors,..the dyno guy suggest i get 310's and try to run a lil higher boost... would getting a better wastegate help with performance also? may be like a 35mm tial or something?
Old Jun 3, 2002 | 09:55 AM
tmg's Avatar
tmg
those figures are nice man. it sounds like your exhast may be robbing some power but your setup is simple but nice. good luck
Old Jun 3, 2002 | 10:18 AM
enigmaspeed27's Avatar
Default Re: Hey guys, i dynoed my ride.. (themi6group)
Try getting a ECU from Hondata.com My friend has one on his car and it gave him 30hp. He got 00' Civic Si.
Old Jun 3, 2002 | 10:25 AM
b18tdelsol's Avatar
Default Re: Hey guys, i dynoed my ride.. (enigmaspeed27)
yeah..i think hondata will be in my future plans, but i dont anything that soon. my main goal this summer is to run mid to high 13s. i will be happy. but secondly achieve about 250 whp. is there alot of differnce between running a 2.5 down pipe to a 3 inch exhaust, compared to 2.5 straight all the way through?
Old Jun 3, 2002 | 10:29 AM
badCRX's Avatar
New User
don't waste your money on cams. That will probably be the last thing you want to do. I agree with everyone else on injectors and maybe an S-AFC for tuning. Hondata and a wideband O2 will be good choices too.
Old Jun 3, 2002 | 10:50 AM
SIK IN DA HED's Avatar
New User
Default Re: Hey guys, i dynoed my ride.. (badCRX)
where did you get your car tuned at? he mentioned gettin 310s? did he also recommend changin your FMU rate? because you will run rich if you get the 310s without changin out the fmu ratio.
Old Jun 3, 2002 | 11:07 AM
b18tdelsol's Avatar
Default Re: Hey guys, i dynoed my ride.. (dlplayboy)
i dont think he metioned about changing the fmu rate. that was what i was wondering also.. is it prety simple to change out the disc on the vortech units? i was thinking about like 8:1 and some 310's.. will it still be rich?
Old Jun 3, 2002 | 11:46 AM
modvp's Avatar
i think 6:1 would be fine with the b18b. i have a b18b and i'm getting 310cc to run with 6;1. by my calculations, 8:1 maybe too rich.
6:1-- 310cc--fuel pressure--new injector flow rate.
10 psi boost, 95 psi fuel pressure 461cc flow
9 psi boost, 89 psi fp 450cc flow
8 psi boost, 83 psi fp 430cc flow
7 psi boost, 77psi fp 415 cc flow...
43 psi was use as base injector flow in calculations
for 310 cc at 8:1 FMU disc...
10 psi boost 115 psi fuel pressure 507cc injector flow
9 psi boost, 107 psi fp, 489 cc
8 psi boost, 99 psi fp 470cc
7 psi boost, 91 psi fp 451cc
so in my opinion, 8:1 may be too rich.
Old Jun 3, 2002 | 11:52 AM
modvp's Avatar
base fuel pressue on my B18B is 35 psi.
therefore, 10 psi x 6 (fmu) + 35 = 95 psi.
for new injector flow...Sq root of 95/43 x 310cc = 460.775cc
Old Jun 3, 2002 | 12:22 PM
*Boostwerks*'s Avatar
Technically that is correct, IF your pump/fuel system can even handle the pressure.
Old Jun 3, 2002 | 12:30 PM
modvp's Avatar
Default Re: Hey guys, i dynoed my ride.. (Bryson)
"Technically that is correct, IF your pump/fuel system can even handle the pressure."
Now i am running at least 125 psi with the airtex pump and stock injectors for over 2 years...
anything to lower fuel pressure will be okay as long as i am getting the correct fuel to the cylinders.
[Modified by modvp, 9:31 PM 6/3/2002]
Old Jun 3, 2002 | 12:40 PM
New User
so what are you guys tryin to say? hahah isnt it better to be rich than risk the chance of bein lean?
Old Jun 9, 2002 | 07:24 PM
tonydatyga's Avatar
injectors, open dp, practice traction and you'll have no shame at the track. 250 will have you begging for drag radials at the least
gpomp
Jun 2, 2012 10:36 AM
00civicsohc
Oct 23, 2005 04:53 PM
SSBPGSR
Aug 26, 2004 08:55 AM
Ad4mGSR
Jul 23, 2004 11:45 PM
_Shadow_
Jun 11, 2002 07:12 PM
