keyless entry for lx
my girl just bought a 03 lx, now i has power locks but what is needed for keyless?
when i got my 99 si all i had to do was buy a new remote, is that possible on this?
if not what type of modifications are needed in order to get it done, thanks for the help guys
well, im not sure what other type of lx you can get. it didnt come with a remote so i guess what im asking is how can i tell if it has the thing that detects the transmitter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shintakun »</TD></TR><TR><TD CLASS="quote">no i went and asked the dealer ship keyless entry is not in any LX from 01-04 and some late 04 models have them. because i went to go buy window inserts and thier oem filters</TD></TR></TABLE>
Your dealer is wrong. If you do a little research, the lx from 2001 - 2004 comes with the keyless entry as an option. Correct me if I am wrong but from what I have found this is true. So to say that none of them had keyless would be wrong. I actually just purchased an 01 lx. The car was purchased without remotes and all we had to do was buy 2 new remotes for 35$ on ebay and an actuator for 30$ from Honda.
Now the easy part is to find if the car is set up with keyless entry. There should be a panel in the dash where the cigarette adapter plug in is. Pull that all out and behind there will be a keyless entry module box. It should have the fcc code on the back and a canada code too. You should match this with the remote that you buy on ebay. If you do not see a little black box behind there then you do not have keyless entry installed. The only bad part about not having it is the fact that Honda discontinued it just recently.... I hope this helps. Any more questions just let me know... thanks.
Josh R.
Josh R.
my god thank you sooooo much. im gonna have a look tomorrow morn and will provide an update.
i looked on majestic for the kit (they didnt have pics) but it was listed at around $120. i hope they do have some in stock, but ive ordered alot of parts for my civic and getting calls form them stating i cant get what i had ordered since they dont update the site very often is nothing new to me
:crosses fingers:
:crosses fingers:
Keyless comes in lx, hx, gx as an option. You have to purchase a keyless module to add remotes. If you buy the car used then there is a possiblity that one might be installed.
I have Extra remotes if anyone is interested. In good condition $10 shipped with programming instructions.
If anyone has an EX, LX, GX, HX.....I have a Honda security system for sale. Comes used will all documents and installation instructions. Retails for over $169. Make me an offer.
fiveten
fiveten
hi just bought my girl the same car (2003 civic LX) and I have almost the exact same question -- remote does not lock/unlock and wondering if the car has keyless entry installed.
Found this web page (http://handaaccessories.com/civelec01.html) that has a link that gives detailed instruction for installation of the keyless unit -- the issue is that Honda discontinued it so you cannot buy it from this site, maybe some after market place. However the instructions do tell you what's involved and perhaps even how to find out if your car has the unit installed. The delsol93guy reply is consistent with what's said in the manual.
if you find a good after market place to buy this unit please share it. Thanks.
Just because they are discontinued does not mean there are none to be found.
Here is a list of dealers that show at least one in stock. Good luck!
WALKER HONDA ALEXANDRIA LA (318)445-6677
GREG MAY HONDA WACO TX (254)420-4740
ORR HONDA TEXARKANA TX (903)794-6632
SAND DOLLAR HONDA GALVESTON TX (409)744-5711
BIG ISLAND HONDA-KON KAILUA KONA HI (808)329-8101
KEN GARFF HONDA DOWN SALT LAKE CI UT (801)526-1700
JACK O DIAMONDS HOND TYLER TX (903)561-5225
MIKE PIAZZA HONDA LANGHORNE PA (215)702-1500
KEN GARFF HONDA OGDE OGDEN UT (801)627-6701
TIPTON HONDA EL CAJON CA (619)440-1000
JOE MARINA HONDA TULSA OK (918)496-7833
THE AUTOMASTER HONDA SHELBURNE VT (802)985-8482
HUNTINGTON HONDA HUNTINGTON NY (631)423-6000
BURLINGTON HONDA BURLINGTON NC (336)584-4870
LEE HONDA AUBURN ME (207)783-7080
LIA HONDA ALBANY NY (518)438-4555
GATEWAY HONDA PORT RICHEY FL (727)848-0688
WALNUT CREEK HONDA WALNUT CREEK CA (925)934-0530
PATTY PECK HONDA RIDGELAND MS (601)957-3400
WILLEY HONDA BOUNTIFUL UT (801)295-4477
HONDA OF KINGSTON KINGSTON NY (845)338-5400
KEN GARFF HONDA OF O OREM UT (801)714-2200
VAL STROUGH HONDA SEASIDE CA (831)899-4191
MCDAVID HONDA HOUSTON TX (713)948-1900
CURRY HONDA CHICOPEE MA (413)593-6727
CARL HOGAN HONDA COLUMBUS MS (662)328-8236
HONDA BLOOMFIELD BLOOMFIELD H MI (248)333-3200
LUMBERTON HONDA LUMBERTON NC (910)739-9871
RELIANCE HONDA LAKE JACKSON TX (979)237-0400
HONDA OF PARIS PARIS TX (903)784-9400
HONDA CARLAND NORTH CARTERSVILLE GA (770)382-2282
Its connected with the little tension clips. Just pull on it and it should slide out without a problem and then to reinstall it just push until the clips are in. If I were you though, I wouldnt do this very often otherwise you will have a greater risk of loosing a clip or having the clips loose their "tension" and your piece will not stay in.
Good luck with it.
Good luck with it.
littleblue
Audio / Security / Video
Jul 12, 2006 06:10 PM
