KYB AGX for GSR???
741007 rear part numer
The rear's should have the adjustment dial on the top of the shaft of the shock (sits inside the car). The bottom of the rear should be forked not loop-holed design.
If the rear shocks you have now have a big fat clock dial on the side of the shock body, then you have the wrong shocks.
[Modified by IN VTEC, 11:51 AM 6/3/2002]
Thats what's got me so concerned, my stock shocks are loop holed. Every other GSR I've seen tho has the square forked design. So i'm assuming my LCA are different too, right?
What other Integra's carry a loop holed design. LS, Type R, GS ??? anybody knows??
I need to replace my back shocks!!!
Yeah I got a 00'LS and just got my new AGX KYB's in the mail two days ago. They are forked at the bottom with the adjustable dial on the top inside the trunk. I think you got the ones for an itr. I almost positive the itr's are the only ones that are diff. from the rest of the G3 tegs.
I dont have any numbers. If you have itr spec rear shocks, you will need itr lca's, regardless if its jdm or usdm. So either trade the itr kyb's for gsr, or get itr lca's.
Ok I just found this out. it seems like some of you got confused about what I was trying to say.
Apparently they are a few, very rare GSR's with LCA that take the loop-holed rear shocks instead of the fork-type. Similar to some civics
I happen to have one of those. What I need to know is what year and type civics carry such LCA and will KYB AGX's for those fit? I already have the front ones in, and need to return the others.
I have no idea what you are saying. I have never seen any gsr's with the itr type lca. So what you are saying is, you have the fork type shock with the itr type lca? I am so confused. Are you canadian?
take a picture of these shocks. I have never seen that loop hole type design except on a ITR. and I didn't think they made KYB's ffor ITR, if they do can someone share the part number. I would like to get them and switch to ITR RLCA.
aw614
Suspension & Brakes
May 12, 2013 01:52 PM
