Removing Orange Peel?
Couldnt find this forum in the search tool so i hope this isnt a repost...
Anyway I just painted my sideskirts and there is alot of orange peel
what would be the best way to remove this? I was thinking 800 / 1500 stepped wetsand then polish? I want it to be smooth and glossy but im afraid the wetsand will kill it....
any advice is greatly appreciated...
what would be the best way to remove this? I was thinking 800 / 1500 stepped wetsand then polish? I want it to be smooth and glossy but im afraid the wetsand will kill it....any advice is greatly appreciated...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">Couldnt find this forum in the search tool so i hope this isnt a repost...
any advice is greatly appreciated...</TD></TR></TABLE>
i wouldnt touch it with 800. id go with 2000 followed by 3000 but thats just me.
what would be the best way to remove this? I was thinking 800 / 1500 stepped wetsand then polish? I want it to be smooth and glossy but im afraid the wetsand will kill it....any advice is greatly appreciated...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi »</TD></TR><TR><TD CLASS="quote">1500 or 2000 grit > 3M Rubbing compound > 3M Finishing glaze</TD></TR></TABLE>
you use nothing inbetween compound and glaze? odd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hye-turbocivic »</TD></TR><TR><TD CLASS="quote">I own a body shop I always do 1500 then 3M Rubbing compound with buffer. glossy </TD></TR></TABLE>
i agree.. 1500, 2000, then cut compound, polish, and finish it with hand glaze... MIRROR SHINE
agree with all, basic tecniques vary on the color, imo 3m products are the best,
and if you are a good buffer you can usually get away with using just 1500, 3m buffing compound, then 3m perfectit glazing polish,
if you are chalkboarding (completely flat) you want to probably go 1000 or 1200, then 1500 or 2000
i personaly would never use 1000 grit paper on blacks or other dark colors unless you are sanding a lot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Rok »</TD></TR><TR><TD CLASS="quote">
you use nothing inbetween compound and glaze? odd</TD></TR></TABLE>
I use a regular rubbing compound on a white pad, then the same rubbing compound on a black foam pad, then on a new black foam pad I use the finishing glaze (no not a hand glaze, a finishing glaze or a "swirl mark remover"). So no, nothing in between compound and glaze, and I've never had a problem, nor have I had swirls, or dull spots from nibbing.
Modified by WihaSi at 11:30 AM 5/29/2007
RACEPAK
11
Mar 23, 2007 01:50 PM
Charlie Moua
18
Mar 14, 2003 10:04 PM
