Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Key question
Old May 28, 2007 | 01:39 PM
mfisher1967's Avatar
Default Key question
The key for the 2007 Civic LX is quite large. This is mainly due to the fact that the keyless entry remote is attached to the key itself. I work in a fairly hot/humid/wet work environment. I am wondering if anyone has had their keyless entry remote fail due to H2O contamination of the electronics?
Old May 28, 2007 | 02:06 PM
TRE_'s Avatar
Default Re: Key question (mfisher1967)
The only time I've seen the newer style keys fail is if they are dropped in water... even then if you pull them out soon enough and allow them to dry they'll usually work just fine. As for being in a humid enviroment it will not cause any problems/damage to the electronics inside the key.
Old May 28, 2007 | 02:35 PM
exhaust_note's Avatar
i threw my friend VW flip key/keypad in a pool and it still worked.
Old May 28, 2007 | 09:44 PM
Floopale's Avatar
Default Re: (exhaust_note)
lol you sound like a mean friend...j/k
Old May 28, 2007 | 10:35 PM
Nighthawk R18's Avatar
i vote to use your vallet key around your work if you worried about gettin it wet. but i think it should be fine.
Old May 29, 2007 | 07:00 AM
FBPSidan's Avatar
Default Re: (Nighthawk R18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">i vote to use your vallet key around your work if you worried about gettin it wet. but i think it should be fine.</TD></TR></TABLE>
Yeah but than you cant unlock/lock doors or pop trunk if needed at your convenience.
Old May 29, 2007 | 11:13 AM
COMplex.'s Avatar
Default Re: (FBPSidan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBPSidan &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah but than you cant unlock/lock doors or pop trunk if needed at your convenience.</TD></TR></TABLE>
The valet key should work in the ignition and driver's door. It won't open a locked glove box or locked trunk latch.
You can still use the trunk release on the floor as long as it's unlocked.
Old May 29, 2007 | 11:43 AM
seed2harvest's Avatar
* B A N N E D *
as far as something small, like a key, should have no problems.
i had my boss radio in my bathroom, eventually the steam killed it. but thats way different.
Old May 29, 2007 | 03:38 PM
I appreciate all of your replies. I will just use one of those detachable key rings, car key on one ring and other keys on the second ring. I will then be able to lock my car key in my desk on days that it is raining while I carry around all of my other keys.
Old May 30, 2007 | 01:40 AM
20strong's Avatar
Well it looks like you have solved your problem. I'm sorry to jack here but does anyone know were to find a CTR key that would work with our Si's?
Old May 30, 2007 | 08:18 AM
IT GUY's Avatar
Default Re: (20strong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20strong &raquo;</TD></TR><TR><TD CLASS="quote">Well it looks like you have solved your problem. I'm sorry to jack here but does anyone know were to find a CTR key that would work with our Si's?</TD></TR></TABLE>
Japan.. j/k
seriously, is there a difference? got pics?
Old May 30, 2007 | 08:24 AM
FBPSidan's Avatar
Default Re: (IT GUY)
It has a red "H" on the back from what ive seen
Old May 30, 2007 | 05:42 PM
20strong's Avatar
That is the only difference that I know of.
hai1234
Honda Civic (2001 - 2005)
Dec 28, 2023 06:51 AM
petertiernan64
Audio / Security / Video
May 15, 2017 03:41 AM
Fa1_Sean
Dec 5, 2014 12:34 PM
YAH YAH
May 25, 2007 10:57 PM
raylude
Jan 23, 2005 09:52 AM
