99-00 Civic Radiator Fan Switch
I was wondering if anyone knows where the Radiator fan switch is located on a 99-00 civic? Also, how easy is it to remove and install a new one?
If you are talking about the "thermoswitch" its located on the thermostat housing. Part of your wire harness will be plugged into it. Its really simple to take out. I just did a rad flush at the same time and drained my coolant, unplugged the connector and i believe i used a 22mm or 24mm closed end wrench. Its one of the two. Should take you about 1 minute to take out.
alpinegroove
Oct 22, 2013 10:27 AM
LOVEthatDC2
Aug 17, 2011 10:03 AM
phoxking
Apr 10, 2011 02:05 PM
