how do you....
The middle and driver side? Remove the two screws above the cluster, pop off the hazard switch with a flathead to expose a third screw, and then pry from the driver side vent using a flathead.
The top center? Use a flathead and pry on the passenger side.
The small top ones? Use a flathead and pry out.
The passenger side? Use a flathead and carefully pry. It will take some time to remove.
saywhat
May 11, 2006 01:33 PM
karmannghia
Nov 7, 2001 07:51 AM
