rack and pinion
Old May 28, 2007 | 09:13 AM
Rev Red's Avatar
Default rack and pinion
i just want to know if anyone makes performance rack and pinions for a 91 crx si?
i got a rebuild one but it only lasted me like on year. or even if there are a good honda ones that fit.
thanks
Old May 28, 2007 | 10:39 AM
mahatma's Avatar
Default Re: rack and pinion (Rev Red)
quaife
Old May 29, 2007 | 08:40 AM
Andy R's Avatar
Default Re: rack and pinion (mahatma)
quaife only makes it for the dx rack. Only modified Si rack i've seen is the one ENDYNE did, but it was a custom machined and modified quaife unit.
Old May 29, 2007 | 08:45 AM
SiRay13's Avatar
Default Re: rack and pinion (Andy R)
Hf rack housing will work also for the quaife rack and pinion- Id have to say it's one of the best investments in my car.
Modified by SiRay13 at 10:56 AM 5/29/2007
Old May 29, 2007 | 09:02 AM
whiskeypiss's Avatar
There isn't much to a rebuild when it comes your steering rack. Out of curiosity what went bad a year later with your rack?
Old May 29, 2007 | 10:48 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy R &raquo;</TD></TR><TR><TD CLASS="quote">quaife only makes it for the dx rack. Only modified Si rack i've seen is the one ENDYNE did, but it was a custom machined and modified quaife unit.</TD></TR></TABLE>
the DX rack fits on the Si chassis. DX and Si racks are different but are interchangeable.
endyn is a hack who couldnt figure out that the quaife unit was made for the DX rack and went about the dumbass way of "modifying" an Si rack to fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiskeypiss &raquo;</TD></TR><TR><TD CLASS="quote">There isn't much to a rebuild when it comes your steering rack. Out of curiosity what went bad a year later with your rack?</TD></TR></TABLE>
i agree, its just a rack end bushing and maybe the pinion bearing that could possibly be "rebuilt" on a manual rack itself. also the gearbox adjustment can be played around with too.
btw, something to check out in steering play is the pinch bolt at the Ujoint/pinion at the bottom of the steering column.
http://www.crxcommunity.com/vi...light=
Old Jun 4, 2007 | 12:35 PM
REDBARON's Avatar
Default Re: rack and pinion (Tyson)
Sorry to bring this back from the dead but I just replaced the bushing this weekend and it was very easy to do. I had the bushing out in about 5 minutes. I purchased the rack used with the subframe still attached and it was very easy to get out. If anyone has any questions about it, let me know.
Old Jun 4, 2007 | 12:37 PM
Tyson's Avatar
Default Re: rack and pinion (REDBARON)
yes, if the rack is out of the car, its very easy.
which is why i suggest ppl to take the time to remove the rack completely instead of trying to work on it under the car.
Old Jun 4, 2007 | 12:52 PM
REDBARON's Avatar
Also, you don't need to remove the tie rods in order to remove the rack from the car. It
Sikocivic
42
Oct 10, 2020 11:14 AM
GeoMetry
May 11, 2014 12:24 PM
Rene M
45
Mar 22, 2006 09:20 AM
SiRay13
Suspension & Brakes
Mar 9, 2006 03:27 PM
