ARP Main Stud and Girdle question!!!! HELP!
Old May 28, 2007 | 07:19 AM
$ISELLTOU4LESS$'s Avatar
Default ARP Main Stud and Girdle question!!!! HELP!
Ok, So here's the story, I have a B18B motor, and I am going to stud it with ARP head studs and a new headgasket, I am going to use a Cometic Head gasket, as I have heard they are the best. SO here's my question, is it possible for me to buy ARP main studs and an Endyn Block girdle for my LS and jack up my car and take off the Main Bolts and caps, and just use the bearings and tighten them back up!? I am not sure if you HAVE to MIC new bearings in there, pretty much pull the motor, mic new bearing and while ur at it put in new piston rings. I jsut want to strengthen up my bottom end without having to pull the motor yet. I will pull it in the future and build it, but would this be possible if I just pull off the oil pan and put in Main Studs and tightened up a new block girdle and all on there with the same bearings, I don't think there is anything wrong with the bearings, as the motor runs pretty good, (not saying that is any indication of bearing wear or life.)
Well, LMK everyone's opinions. I would jsut like to know if it is possible without it destroying the motor, I know the right way to do it is to pull the motor and MIC new bearings and all, and if this would cause any problem more than jsut leaving it the way it is, I won't do it.
Thank Ahead!
Old May 28, 2007 | 01:02 PM
Default Re: ARP Main Stud and Girdle question!!!! HELP! ($ISELLTOU4LESS$)
wow noone has an answer to this!?
Old May 28, 2007 | 02:49 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $ISELLTOU4LESS$ &raquo;</TD></TR><TR><TD CLASS="quote">wow noone has an answer to this!?</TD></TR></TABLE>
Can you..sure. Should you .....of coarse not.
Why do you think you even need main studs and a girdle.As far as a head gasket the oem ones are great.The stock block and caps are good for well over 500hp.
That's my answer.
Old May 28, 2007 | 02:54 PM
Default Re: ARP Main Stud and Girdle question!!!! HELP! (NJIN BUILDR)
IDK the only reason I ask if for strength reasons. I am going to turbo my LS on 10PSI with head studs so I don't get any head lift with boost, I want it to be reliable and quick. I will take any measure I have to short of pulling the motor and building the bottom end. I jsut know th stock block record for LS is like 360 +- HP. Now don't get me wrong 300 HP in a 92 Civic hatch is plenty fast for me right now. So you think it will hold up fine with headstuds. So what gives on those bottom ends on turbo then!? Is it the rod bolts,rods or what!?
Old May 28, 2007 | 03:24 PM
Where are this records kept (360hp).If you have stock rods and piston they will fail long before the main caps and bolts will.I was talking about the girdle and MAIN studs.The head studs are a good idea.You need to take some time and read this thread. https://honda-tech.com/zerothread/1323059
Old May 28, 2007 | 04:41 PM
Read that thread, very informative. Thanks again, so basically jsut stud it and cross my fingers huh!?
Old May 28, 2007 | 04:59 PM
[QUOTE=$ISELLTOU4LESS$]Read that thread, very informative. Thanks again, so basically jsut stud it and cross my fingers huh!?[/QUOTE
In one breath you say you want it reliable.In the next breath you say you won't pull the engine and do things the right way.I'm not above a quick fix in a pinch,but in chassis rebuilds aren't the way to go for reliability.
Old May 29, 2007 | 04:53 AM
No, I just meant by the standpoint fo the fact that if I do pull it, it is going to get FULLY BUILT, rods pistons block and all, and then jsut go LSVTEC from there, I don't want to pull it cause it is my Daily Driver thats all, but I can put ARP headstuds in it and make it strong, BUt that thread I saw people running on 150k miles with stock EVERYTHING, I will at least have a lower mileage engine with new HG and new head studs. But by the looks of it my car should handle 10 PSI very nicely until I want to upgrade for a lil more power. AlsoI think it would hold well at 12 PSI too, but we will see how 10 does. , but I REALLY appreciate that thread.
Old May 29, 2007 | 07:33 AM
Godspeed07's Avatar
Do a full build....cmon you know you want to
Old May 29, 2007 | 04:29 PM
Default Re: ARP Main Stud and Girdle question!!!! HELP! (Godspeed07)
I do MY WALLET doesn't want to and can't.
Old May 29, 2007 | 07:01 PM
The first thing that fails is the pistons on a stock LS.If you stay out of detonation you should be fine.Before I even put head studs in I would spend the money on a ems and a tune.
Old May 30, 2007 | 05:48 AM
Well, the Hondata S300 EMS will be on the same exact time the turbo goes on. It will Be EMS, Tune and Studs. I am not gonna play around with that, I am sure the stock head studs will work, I just don't trust them personally. and a new HG will be nice.
ANd I am correct in that I can use the stock Honda MAP sensor up to 11PSI correct!?
Old May 30, 2007 | 08:05 AM
Golden Eagle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $ISELLTOU4LESS$ &raquo;</TD></TR><TR><TD CLASS="quote">Well, the Hondata S300 EMS will be on the same exact time the turbo goes on. It will Be EMS, Tune and Studs. I am not gonna play around with that, I am sure the stock head studs will work, I just don't trust them personally. and a new HG will be nice.
ANd I am correct in that I can use the stock Honda MAP sensor up to 11PSI correct!?</TD></TR></TABLE> just use a oem gasket comitic is known for failing even eggum uses a oem gasket, if she can do 7 sec passes on oem gasket im sure it will work for you
Old May 30, 2007 | 04:22 PM
Default Re: ARP Main Stud and Girdle question!!!! HELP! (Golden Eagle)
OEM is fine, they are jsut more expensive, that was all. LOL
Old Jun 1, 2007 | 04:47 AM
So best thing i can do is Stud it with an OEM 3 layer, use good oil and pray huh!?
Old Jun 1, 2007 | 06:15 PM
Pray about what ?
Old Jun 2, 2007 | 07:38 AM
That it doesn't blow the F*@k up!
Old Jun 2, 2007 | 12:52 PM
Well everyone says that prayer once in a while.But remember that God hates a coward.
Old Jun 3, 2007 | 06:44 AM
Well, It seems people are running on 200,XXX mile motor and boosting 10PSI so I should be AIGHT. But w/e I guess if it blow it blows..............Hello D series again. Hahaha
Old Jun 3, 2007 | 05:52 PM
blackeg's Avatar
hey dude, you dont need a girdle. i used to rev my 210K + ls turbo to 7400 no probs. now i rev my lsvtec (all aftermarket but still no girdle) to 8500 again no probs
Old Jun 3, 2007 | 09:04 PM
Default Re: ARP Main Stud and Girdle question!!!! HELP! (blackeg)
I jsut wanted something to make it stronger. Well, now I need a .63 Exhaust housing for my car. ANyone want to trade for my Brand NEw .48 a/r Garrett!?
lupin5
May 4, 2010 04:53 PM
MeathooK
Jun 19, 2008 12:35 AM
llloyd
14
Apr 27, 2008 04:22 PM
SoSlo
Nov 29, 2007 03:51 PM
NA JDM GSR
Oct 16, 2006 10:22 AM
