City light bulb?
So i installed jdm head lights with the city lights in my 95 ex and purchased the normal amber 194 bulb but it is quiet dim. So the question is: Are there any other lights that give a brighter output but still fit in the socket?
for the city lights doubtfully. theyre really used as sidemarker bulbs in most cars. you could try finding a higher wattage bulb but i dont think there is any b/c of the use of it. but then youd have to worry about youre wires bight able to handle more wattage. id say the only way to make the brighter is a clear or blueish bulb but that kinda ruins the idea of the jdm lights. so i guess good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic »</TD></TR><TR><TD CLASS="quote">amber is a jdm look. id do amber and sacrifce light to be jdm. the city light is intended for the day time. not a night time driving light.</TD></TR></TABLE>
you couldn't be more incorrect, the stock city light bulbs are white, and they are used at night time, not day time running lights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2coupes »</TD></TR><TR><TD CLASS="quote">you couldn't be more incorrect, the stock city light bulbs are white, and they are used at night time, not day time running lights</TD></TR></TABLE>
That about sums it up.
Just use a standard, clear 5 watt wedge bulb such as a 194/168.
hey man i juss purchased the jdm heads for my 94 hatch juss wondering how you connected the wires because i have to cut mine
have any pics?
Modified by hafaadaiteg at 10:40 PM 5/28/2007
have any pics?
i took the three wires form the fatory harness and cut them and ran i believe it was the red/striped wire to the city light as that was the parking light in the usdm assembly and the ran i believe it was the green/striped wire to the turn signal socket. Then used the common ground for both wires.. Works perfect
SFlCrx
May 17, 2006 07:22 PM
