--any good ECU chips?--
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegda »</TD></TR><TR><TD CLASS="quote">i want to know if there are actually any decent performance chips, maybe that could change me redline to about 9ish rmp</TD></TR></TABLE>
Yeah, ones that are based off a dyno tune of your setup.
What do you have done to the motor to warrant revving to 9k?
If you will be installing a turbo soon, just wait until everything is installed and then have the setup properly dyno-tuned with a wide-band O2. You shouldn't be using a generic chip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">If you will be installing a turbo soon, just wait until everything is installed and then have the setup properly dyno-tuned with a wide-band O2. You shouldn't be using a generic chip. </TD></TR></TABLE>
Defiantly.
Get yourself a EEPROM chip from xenocron.com
Or Moates.net. then get a base-map with turbo columns on it, to limp you to a dyno.
Defiantly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegda »</TD></TR><TR><TD CLASS="quote">turbo within the next 2 weeks and i jst want to know of any good chips</TD></TR></TABLE>
installing a turbo doesn't mean you'll be able to rev to 9k without blowing up your engine. leave the redline alone if you aren't done head work. like others said don't get a generic chip, get a socket put in and get it properly tuned.
