b18c1 valve cover modification
Old May 27, 2007 | 07:33 PM
boost-em-now's Avatar
Default b18c1 valve cover modification
I want to put the moons in my valve cover for my cam gears, but i dont wanna mess it up. wat would be the best do it yourself way to go about it?
Old May 27, 2007 | 07:41 PM
Eran's Avatar
HT White Ops
With a jigsaw capable of cutting metal and a grinding wheel on a dremel.
Or just with a cutting wheel.
Old May 27, 2007 | 07:50 PM
Default Re: (Eran)
it would crack or chip the paint around the cuts?
Old May 27, 2007 | 07:51 PM
Eran's Avatar
HT White Ops
Default Re: (boost-em-now)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost-em-now &raquo;</TD></TR><TR><TD CLASS="quote">it would crack or chip the paint around the cuts?</TD></TR></TABLE>
It's a distinct possibility. That's why you use something nice and sharp.
Old May 27, 2007 | 07:58 PM
Padawan's Avatar
Darth ModerVader
Default Re: b18c1 valve cover modification (boost-em-now)
I'd suggest picking up a cheap used valve cover for tuning. You can hack it up all you want, install it while tuning, and then re-install your original one after you're finished. You'll be guaranteed not to damage yours, and you'll also eliminate the possibility of any debris making its way into the timing belt area through the cut-outs.
Old May 27, 2007 | 08:01 PM
Eran's Avatar
HT White Ops
Default Re: b18c1 valve cover modification (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I'd suggest picking up a cheap used valve cover for tuning. You can hack it up all you want, install it while tuning, and then re-install your original one after you're finished. You'll be guaranteed not to damage yours, and you'll also eliminate the possibility of any debris making its way into the timing belt area through the cut-outs. </TD></TR></TABLE>
A much better suggestion than mine. Granted, I would never cut my daily valve cover.
Old May 27, 2007 | 08:04 PM
Default Re: b18c1 valve cover modification (Eran)
good call..........ima prolly do that
GrnZ
Apr 10, 2008 11:52 AM
R.and.Y
Paint and Body
34
Jun 14, 2007 07:25 PM
DFW
Aug 29, 2005 11:16 PM
01ITR#173DC2ning
Feb 11, 2005 08:35 PM
i3luemrld
Jan 19, 2004 11:54 PM
