ignition coil question
Old May 27, 2007 | 02:51 PM
saikou's Avatar
Default ignition coil question
I was going to swap out my ignition coil into a friend's car to see if his coil was causing his problem. The coil plug wire popped off of his coil with no problem, however, mine seems entirely different. How do I take this wire off?
Old May 27, 2007 | 02:54 PM
preludefien
Guest
Posts: n/a
Default Re: ignition coil question (saikou)
pull it off dude. it comes off
Old May 27, 2007 | 03:07 PM
InvaderTrax's Avatar
Gently work it out. Don't just yank our you risk ripping the plug off the wire
Old May 27, 2007 | 03:14 PM
saikou's Avatar
Default Re: (InvaderTrax)
It doesn't even appear to be the correct wire set, that or its a fairly cheap wire set; previous owner. Pulling on it does nothing and if I pull on it much harder, as InvaderTrax mentioned, it will just rip the wire from the plug.
Old May 27, 2007 | 03:38 PM
Hawkze_2.3's Avatar
Default Re: (saikou)
So the wire won't come out of the green part? If it's not a tight fit the spark will have to jump a gap and that can melt things like plastic and metal Might be welded in there...
Old May 27, 2007 | 03:43 PM
saikou's Avatar
Default Re: (Hawkze_2.3)
Yup, wire will not come out of the green part. Its a very tight fit... can't get the damn thing out.
Old May 27, 2007 | 03:58 PM
preludefien
Guest
Posts: n/a
dude it will come out. doesnt matter how cheap the wires. were
Old May 27, 2007 | 05:30 PM
mgags7's Avatar
lol chris remember yours.....yeah it came out, and left the plug behind. lol
extremevtecracing
Apr 19, 2026 11:56 AM
B16aCRXSi
Sep 13, 2009 05:36 PM
vtek9
Aug 27, 2007 07:40 PM
dirtySOHC's
May 22, 2003 07:15 PM
MidoriEK4
May 18, 2003 09:08 AM
