02 RSX-s vs 06 rsx-s
Old May 27, 2007 | 01:48 PM
martyball619's Avatar
Default 02 RSX-s vs 06 rsx-s
im in the market for a type S this summer.. and i was told that the 05-06 models are stronger than the 02-03 models. why is this? arent they both the exact same engine?
Old May 27, 2007 | 03:18 PM
Aco512's Avatar
no they're not
most increase performance features are better cams, better exhaust, different gearing (i believe)
Old May 27, 2007 | 03:21 PM
Default Re: (Aco512)
cool..
Old May 27, 2007 | 07:22 PM
jdcdc5's Avatar
Default Re: (DC2SiR)
not much of a difference except looks. very well could be a better cam...gear...etc but i heard its a better tune
Old May 27, 2007 | 07:40 PM
mikestypes's Avatar
Default Re: (jdcdc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdcdc5 &raquo;</TD></TR><TR><TD CLASS="quote">not much of a difference except looks. very well could be a better cam...gear...etc but i heard its a better tune </TD></TR></TABLE>
Actually, almost EVERY part of the 05+ cars where changed/upgraded in some way.
DO a search on the changes for the 05 cars and you will see.
Old May 27, 2007 | 08:06 PM
jdcdc5's Avatar
Default Re: (mikestypes)
is that also including parts on the motor?
Old May 27, 2007 | 09:12 PM
mikestypes's Avatar
PRC Airbox inlet tube
PRC cams
higher flowing cat
PRC b-pipe
higher redline (8300 vs 8100)
stiffer rear engine mount
4.76 Final drive ratio
upgraded synchros in the tranny
7mm lower and stiffer suspension
larger front and rear sway bars
stiffer suspension bushings
increased caster angle for front struts
revised brake pedal mounting bracket for stiffer brake pedal feel
much nicer front seat leather and padding
stiffer front structure with larger strut tower bar
Just some of the stuff off the top of my head. I owned an 02 and 05 TypeS, and the 05 was better in every way.
Old May 27, 2007 | 09:48 PM
DC5Tuner's Avatar
Do you know if I just order a brake pedal assembly if it'll just swap right over or do I have to order a bunch of other parts? A stiffer brake pedal is always a nice thing to have!
I'm guessing it's just the brake pedal assembly is what's different?
Old May 29, 2007 | 12:55 AM
mitcho's Avatar
Hmm, i take my '02 rsx-s up to 8,300 til it bounces..and its bone stock still
Old May 29, 2007 | 04:30 AM
NDzzle's Avatar
the 02-04 type S is 100 pounds lighter than the 05-06 type s
Old May 29, 2007 | 09:31 AM
mikestypes's Avatar
Default Re: (mitcho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitcho &raquo;</TD></TR><TR><TD CLASS="quote">higher redline (8300 vs 8100)
Hmm, i take my '02 rsx-s up to 8,300 til it bounces..and its bone stock still</TD></TR></TABLE>
The stock tach is not 100% accurate. I used to take my 05 RSX close to 8500 rpm indicated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NDzzle &raquo;</TD></TR><TR><TD CLASS="quote">the 02-04 type S is 100 pounds lighter than the 05-06 type s
Actually, it is 73 lbs different and that is due to the significantly stiffer chassis (15% stiffer front, 21% rear), larger wheels, tires, sway-bars, exhaust, and seats.
I also managed to find the list of details from Honda:
Powertrain (Type-S only)
Engine modifications that boost the horsepower of the Type-S model to 210 at 7800 rpm
High performance camshafts
Larger intake duct
Large diameter exhaust pipe
High-flow catalytic converter
6-speed transmission optimized with a lower final gear ratio for quicker acceleration and carbon synchronizers replacing brass on 5th and 6th gears for a smoother shift feel
Chassis
Revised suspension tuning for increased handling precision and a smoother ride
Ride height reduced by 7 mm
More rigid stabilizer bars (front and back for Type-S, front for RSX)
Larger diameter front strut tower bar for Type-S
Inversely wound front springs
Refined steering system for enhanced feel and quicker response
Optimized braking system for increased stopping power and feel
Larger 17-inch alloy wheels and all-season high-performance tires on the Type-S
Body rigidity increased by 15 percent in front and 21 percent in the rear
NVH reduced
Body
More aggressive exterior styling with redesigned front and rear fascias
Redesigned signature 5-sided Acura grille
Redesigned side sills
Redesigned headlight and taillight assemblies
Deck lid spoiler added to Type-S models
Four new exterior colors: Magnesium Metallic, Vivid Blue Pearl, Jade Green Metallic, Blaze Orange Metallic
Interior
Deeply bolstered front seats with thicker cushioning material
New chrome and titanium-look accents
Old May 29, 2007 | 09:37 AM
NDzzle's Avatar
nice I was looking for that info cuz every site i go to sucks!
Old May 29, 2007 | 01:13 PM
GradyDC5's Avatar
02-04 Mean Track look 05-06 Luxo Import Style
Old May 29, 2007 | 06:27 PM
Default Re: (ReallySlowEg)
ill prolly just invest in a 02 model and throw in some toda camshafts
silver_gun
23
Jul 29, 2007 06:52 AM
TheDR
Honda Civic (2006 - 2015)
75
Jun 17, 2007 09:36 PM
94typeR
Honda S2000
74
May 16, 2007 01:45 PM
ActiveAero
12
Nov 3, 2003 01:43 PM
Littleton
Sep 15, 2003 10:12 PM
