rear disc swap
you most likely wont use anything from you drum swap. just keep your compensator arms, upper control arms, lower control arms. if you decide to get ss brake lines, order a set for a 90-91 crx si.
from what car are you getting your swap from?
88 si crx did not come with rear disc swaps, so if you order them for that year car the rear lines will not bolt on to the calipers since they were designed to fit drums. the fronts will fit, but the rears wont, so if you do the swap order for the 90-91 si crx. so yes you would have to order new lines. im not sure if you could just order only the rears, since you already have the fronts. maybe the rears could be modified? im not too sure, maybe take them to a shop and see.
needashell1234now
Feb 18, 2007 05:40 PM
