F20B/C and Accord SiR-T questions
Old Jun 3, 2002 | 12:15 AM
MoBlack's Avatar
New User
Default F20B/C and Accord SiR-T questions
I'm getting hooked up with a F20C LongBlock this week and I was wondering what can be interchanged between the F20B and C engines...
Anyone have info on this? Or a site I could read up on F20 specs?
Thanks
Old Jun 3, 2002 | 10:20 AM
Katman's Avatar
Default Re: F20B/C and Accord SiR-T questions (MoBlack)
Thanks
You can swap over almost any H22/H23-->(SiR-T) DOHC VTEC parts (cams, head, tranny, etc). The Accord SiR F20 engine is the same exact engine as an H22, just has a different block code since the motor is destroked to 2.0 liter; don't ask me why Honda did that...they're unorthodox/weird like that.
Old Jun 3, 2002 | 04:28 PM
RedlineUBRF's Avatar
I thought F20A and F20B were accord engines and the F20C was the stook engine?
Old Jun 4, 2002 | 12:27 AM
Katman's Avatar
Default Re: F20B/C and Accord SiR-T questions (RedlineUBRF)
stook engine? do dat got vtec? o_O
Old Jun 4, 2002 | 09:53 AM
Daemione's Avatar
That's correct. There's nothing compatible between the F20c & the other F series engines. If anything, there might be some shared parts in the K series, as they're more closely related to the S2000 engine.
Katman - what is your source for the H/F compatibility information? I have heard this from several people, but noone seems to be able to confirm it. Specifically, I'd love to know if the possibility exists of using the F20a/b crank to destroke the H22. And is the F22 95mm stroke crank the same as the 95mm stroke crank found in the H23? How about heads? Would an H22 VTEC head bolt on to a F series block? I assume motor mounts are comparable, since we see H22 Accord swaps fairly frequently.
Basically, I'm toying with the idea of an H22 - destroked to 85mm, resleeved & bored to 90mm. Slightly more displacement than stock, and a 1.749 r/s ratio. Trying to figure out what the most economical way of doing it would be.
Old Jun 4, 2002 | 01:15 PM
MoBlack's Avatar
New User
Default Re: F20B/C and Accord SiR-T questions (Daemione)
I remember seeing a video from Japan where Spoon -I think- wedged an F20 into the Civic-R. What tranny could they have been using?
I the powerband on the F20C and it would be great to have it in a hatch, but if it's not doable (relatively easily) then I'll just piece together the rest of the parts needed to sell it.
Also, does anyone have a link to that video?
Thanks
[Modified by MoBlack, 3:07 PM 6/4/2002]
Old Jun 4, 2002 | 01:30 PM
Daemione's Avatar
It would have had to have been the F20c 6-speed transmission - it rotates opposite from all the older engines.
I'm surprised it fit at all in a FWD application - the F20c wasn't really designed with a transverse mounting in mind. I would have thought it'd be pretty long. But then, a short engine would help weight distribution in the S2000, so I suppose it makes sense.
Old Jun 4, 2002 | 01:53 PM
Katman's Avatar
I thought F20A and F20B were accord engines and the F20C was the stock engine?
--> well i'm not super famlier with all of the Accord/F-series engines, but whichever one is the SiR/DOHC VTEC engine, it's like i said, an H22 engine restamped with F20x and is 2.0L. The head and the heads internals are the same as an H22 -- same mechanical parts. Same goes for the block too, except the block internals being 2.0L (not sure of the piston dome/compression ratio)
-->Random Japanese literature I have.
-->well I've never really messed with an Accord SiR or even H-series engines at all. I do have a friend who has an SiR-T/H23A engine dropped into his 94 accord wagon. Rare motor H23block w/H22 head from the factory.
--> well you're getting too deep into it for me. Again, my knowledge on H/F series engines is limited...I just know that the Accord SiR & SiR-T engines are exactly the same as an H22 engine minus the engine code stamp and the liter size.
Old Jun 4, 2002 | 02:12 PM
MoBlack's Avatar
New User
Default Re: F20B/C and Accord SiR-T questions (Katman)
So it looks like I'll want to find a K20A and see if the tranny has any chance of mounting to the block I have. I'm highly doubtful, but I know it's been done... ah the search is on.
I was hoping I could use the F20B crank and tranny, the F20C block and head, and some of the intake/exhaust parts from the Accord SiR-T. blah, oh well...
MoBlack
[Modified by MoBlack, 3:15 PM 6/4/2002]
Old Jun 4, 2002 | 04:00 PM
Katman's Avatar
MoBlack
hmm....I dunno about the K-series workin on any pre 02 cars at all..
Old Jun 4, 2002 | 04:33 PM
98DC2-ITR's Avatar
Please note that there are different HP versions of the F20B out there. The AT version only does 180 HP and the MT version does 200 HP. My AT figure may be off by 5 HP but I do know there is a difference. I have a page bookmarked @ home. I will see if I can find it and post it. It has all the F20B info on it....I have saw several of these engines in person. They look like an H22 that has a Blue valve cover. Neat little de-stroked h22....
Old Jun 4, 2002 | 11:35 PM
Katman's Avatar
Default Re: F20B/C and Accord SiR-T questions (4thapack)
.....I'm pretty sure the HP differences between the AT & MT versions of the F20 are reflected in the camshaft profiles & ecu tuning....in contrast to DOHC VTEC B-series AT & MT engines..
Old Jun 5, 2002 | 08:44 AM
MoBlack's Avatar
New User
I finally picked up the block/head last night. Damn, everything is in great shape except for the #2 piston top and one of the intake valves(overrev == bad). Chain drive, yum.
Anyone have a good source for stock s2k drivetrain/valvetrain parts?
I'll take pictures if you guys want to see. Damn this thing is clean. If I don't end up selling it, I'll just tear it down and learn about this neat little motor.
MoBlack
Terrj
Mar 2, 2010 09:49 AM
omarisramo
Sep 9, 2007 06:54 AM
infinkc
Dec 19, 2001 02:10 PM
