need help, integra wont start.
Old May 27, 2007 | 12:53 PM
stolen_rims's Avatar
Default need help, integra wont start.
Im sure most of you are much more familiar with this cars electrical/fuel system then I am, so I figured maybe someone might recognize the problem Im having. I'll first provide some bg info.
1)its a 94' gsr
2)it hasnt been started in 5yr+
3)when it was in use, it worked great.
4) basic **** it needed was done, new battery, plugs(properly gapped with anti-seize, and dielectric), etc.
5)also cleared off as much rust as I could on all the grounds(the ones i could find).
6)the engine bay is ridiculously dirty. Some of the harnesses look spliced, that Ive never noticed until now.
7)I dont think its the main relay(i hear 3 full clicks)
8)I dont have a multimeter to test the ignition switch(at least not atm).
9)car has new 93 oct gas(5gal), and a bottle or so of octane booster in it.
10) put some oil in it so the piston rings or w/e can get relubed.
Here's a vid of the problem from start to finish.
http://video.google.com/videop...39447
Old May 27, 2007 | 02:20 PM
95 integra's Avatar
Default Re: need help, integra wont start. (stolen_rims)
I would clean the starter terminal and test the starter for a start.
Old May 27, 2007 | 05:04 PM
Default Re: need help, integra wont start. (95 integra)
thanks for suggestion, will do when sun comes up tommorrow, and report back.
Old May 28, 2007 | 06:01 PM
95 integra's Avatar
did that work or not so much?
Old May 28, 2007 | 06:07 PM
sablan02's Avatar
check wire cables. might have to much resistance. iono..just something of the top of my head
Old May 28, 2007 | 06:11 PM
VTEC_PRODUCTION's Avatar
Default Re: (sablan02)
make sure there is spark so check for that...make sure the pump is running and there is pressure at the rail...and then check the timing...start there and then troubleshoot more specifically...
Old May 28, 2007 | 07:51 PM
the contacts(inside) the starter appear to be gone?.....guess I'll buy a new one, but Im sure that is the problem, if not one of them either way. Thanks again.
the ed6 king
Feb 10, 2014 07:33 PM
rehab_this
Oct 18, 2005 07:12 PM
eghatch4sale
Nov 17, 2004 07:36 PM
KeithsDAteg
Aug 12, 2004 08:41 PM
