H22A idles on start up for a few seconds then shuts off!!!! HELP!!
Old May 27, 2007 | 11:13 AM
duceducecord's Avatar
Default H22A idles on start up for a few seconds then shuts off!!!! HELP!!
i have a 96 honda accord LX with a jdm h22a and for some reason when i start up the motor it would idle high then slowly go down but when it goes down it goes down all the way which causes it to shut off... ive been search for help but i haven't heard n e information yet.. hopeeing u guys can help me out !!!!!!
Old May 27, 2007 | 02:57 PM
preludefien
Guest
Posts: n/a
Default Re: H22A idles on start up for a few seconds then shuts off!!!! HELP!! (duceducecord)
do you have all of your sensors and grounds hooked up. did you just do the swap and it just started. give us a little more info..
Old May 30, 2007 | 09:27 PM
Default Re: H22A idles on start up for a few seconds then shuts off!!!! HELP!! (preludefien)
i threw it in and i just drove it. it drove fine til now its still the same CEL lights same everything but i have a feeling i might need a major tune up but im not sure i havent changed n e thing ever sense i got the mottor the only thing ive changed was the spark plugs. but i also have a loose spark plug wire im still getting the connection but then its not like the other ones were it would clip on to the spark plug. do u guys think i need to get new wires?. the one i have on there now are the nology hot wires.i was running a p28 chiped but then it was still doing the same thing so i switched back to the jdm p13 ecu
Old May 31, 2007 | 04:03 AM
PirateMcFred's Avatar
What does the check engine light read?
Address the obvious stuff first then worry about chaning the other stuff.
If you crack the throttle open does it still run or is it only an idling issue?
Old May 31, 2007 | 09:17 PM
Default Re: H22A idles on start up for a few seconds then shuts off!!!! HELP!! (PirateMcFred)
the codes are prim 02, EGR circuit, and tracktion control which i dont have, the car is driveable but im just trying to get the idle issue fixed
Old Jun 1, 2007 | 03:44 AM
The O2 will help with mileage and driving in general fix that at elast then see if your idle improves.
perfectlude
Nov 11, 2014 03:47 PM
cd5_801
Jul 27, 2009 07:04 PM
colocho19
Mar 16, 2009 06:41 PM
poison
Sep 10, 2002 05:45 PM
