Everything seems right, car will not start! Help!
Alright guys here it is. I have a Y8 block with a Z6 head and skunk2 IM. This motor also has a small turbo kit on it. I am just including this info just in case it may matter. I have checked spark (wires and dizzy), new spark plugs, new gas, fuel pump is primeing, fuel rail gets fuel, etc, etc... I have tried using starter fluid in the IM like some people have suggested, and I have checked all my grounds. The car spins over just never cranks. I have no clue as to what this could be. Any help would be much appreciated. Thanks in advance for your time!
The car will spin as long as I turn the key. It will also sputter and pop like it is going to turn over it just never does!
I ordered a brand new dizzy for the motor and it is the right one! I also checked the spark plugs and they are right! I may see if I can ****** a dizzy off my friends CRX and try it. He just put a z6 in that is working just fine. I will try that and holla back in about 30 min!
Check to make sure the dizzy is installed on the engine correct. I put mine on 180 degrees out of time once
and my engine did exactly what you are describing.
I have so far tried everything that you guys have said and nothing has worked. I have swapped the dizzy from a working Z6 to my engine, no luck. I have also tired to install the dizzy another way but there doesn't seem to be any other way that it can be put on so it must be right. I am still at a loss. Thanks for all the suggestions. If you have any more then let me know. I am waiting with tools in my hand !
X2
It's probably your timing. Mine was off one tooth and it was enough to hold the valves open so it couldn't get compression and it did the same thing. This was a z6 head on a b7 bottom. If you've checked....check again. I tried my dizzy also, though it was 180* out and kept coming back to timing issue...
GL
GL
WifesVTEC
Jan 31, 2011 04:46 PM
BB6-213
May 7, 2006 12:52 PM
Hockey27925
Jul 18, 2005 07:17 PM
