??????????different brake swaps amongst chassis??????????????
need some info fellas...
I've been searching online, and I tried searching in here, but have not been able to find info on this, I know honda tuning did a feature on a similar build and I found the link to it, but it still does not answer my question....I want to have a 4x114 setup with larger disks for my cx hatch and since my local junkyard seems to have an abundant supply of four wheel disk braked accords (was considering an ls or gsr brake conversion but they are not so readily avail.) I was wondering if this would work on my hatch.
Any info on this matter will be greatly appreciated and if there is some kind of list with brake swaps among chassis please let me know thanks!!
I know this is more of a tech question....but I wasn't getting any answers in the hybrid section of this site so I thought I'd post it here since this section is viewed more frequently.
thanks in advance
-nick
thanks in advance
-nick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tenedor sports »</TD></TR><TR><TD CLASS="quote">
thanks in advance
-nick</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civhatch90 »</TD></TR><TR><TD CLASS="quote">why are you posting this in the AC forum?? </TD></TR></TABLE>
thanks in advance
READ
READ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraXTC »</TD></TR><TR><TD CLASS="quote">
READ</TD></TR></TABLE>
there is a list of what you can swap in. Go to the Honda civic 92-00 section and check the faq. I don't know how much money you have, but I'm sure you can easily find someone in the classifieds selling a rear disc break conversion. And if you want to have 4x114.3 then your choice would be the 96specR.
4x114 is the same as oem gsr.
just find a trashed gsr and get the brakes. while you at it get the e brake cables..trailing arms...master cylinder...proportining valve off an si. brake lines
4x114 is for looks of the 96 spec itr wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonzer »</TD></TR><TR><TD CLASS="quote">4x114 is the same as oem gsr.
4x114 is for looks of the 96 spec itr wheels.</TD></TR></TABLE>
when did the gsr ever get the 4x114???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .1type. »</TD></TR><TR><TD CLASS="quote">SEARCH is your friend............. try it...
https://honda-tech.com/zerothread?id=1811368</TD></TR></TABLE>
THANK YOU
seriously, I searched but was not able to find it
thanks man!!
THANK YOU
thanks man!!
ummmmm....no
ummmmm....no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokecivic »</TD></TR><TR><TD CLASS="quote">
dont be a smartass. the rotor size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b18c1hatch »</TD></TR><TR><TD CLASS="quote">
ummmmm....no</TD></TR></TABLE>
you're wrong. im sorry. dont be an ***...i have a 4x114 and i know it uses any integra pads that are non type r.
lmfao
lmfao
