Wiring Problem 95 Coupe
Old May 27, 2007 | 08:44 AM
KillaBlackEj1's Avatar
New User
Default Wiring Problem 95 Coupe
Im having a serious wiring problem with my 95 coupe. My headlights tailights cluster almost everything electrical in it is screwed up, theres lots of grounds where there not supposed to be. I want to rip the old wiring in and throw new one in. What harness or wiring do i need to have someone replace it? or what do i need to do in order to fix my problem?
Old May 27, 2007 | 08:48 AM
ke98248's Avatar
Default Re: Wiring Problem 95 Coupe (KillaBlackEj1)
Pix man.
Old May 27, 2007 | 09:36 AM
New User
Default Re: Wiring Problem 95 Coupe (ke98248)
what pics do u want me to show u? it looks like any other cars wiring, i havent followed to lines yet to figure out where it got screwed up but i kno its f*cked..., i just wanna figure out what harness or wiring i need to replace the old one
Old May 28, 2007 | 07:04 PM
New User
bump it up
Old May 29, 2007 | 10:36 AM
Phil_Eg's Avatar
hmm might need a new harness...i had a keypad fuel cut and it screwed everything up but i ended up doing a swap and it fixed itself somehow lol.
Old May 29, 2007 | 10:40 AM
instructor74's Avatar
more info whats screwed up?????????? it could be something simple, mult problems might be caused by one thing. So what isn't working?
Old May 31, 2007 | 07:07 PM
New User
my headlights, cluster, tailights and radio arent workin, my corner lights used to go on but only when i turned the hazards on and now they dont even want to. i tried puttin a test bulb to the headlights wiring and they came up to b like all grounds which is retarded
Old Jun 1, 2007 | 04:02 AM
Default Re: (KillaBlackEj1)
after marker or factory radio? Who did the install if aftermarket? It might be time to pull it and check the wiring. It is not uncommon to blow the fuse to the instrument lighting this also takes out the rear tail lights ect. When an after market deck is installed and the illumination wire is not hooked up and grounds out to the chassis
Luke G.
Sep 25, 2009 07:55 PM
nurvcom..
Dec 2, 2005 07:12 AM
