Suspension & Brakes Theory, alignment, spring rates....
Ingalls camber kit problem
Old May 27, 2007 | 07:04 AM
blaak-crx's Avatar
Default Ingalls camber kit problem
My front Ingalls camber kit was moving on one side. Everything was well bolted in. I analyse the problem: it was at the polyurethane bushings.
We can clearly see the wear on the bushing:
I checked on the site of Ingalls and noticed that they have "polyurethane bushings replacements"! #35701
I just spend on a new set for nothing I guess I will keep my old set as back-up.
Anyone else had the same problem or was it something else that broke on their camber kit?
Old May 27, 2007 | 07:44 AM
goldegg's Avatar
Mine make a tonne of noise and dont even have poly bushings its solid steel, and they are sloppy.
Is the bushing replacement on their site?
Old May 27, 2007 | 10:09 AM
blaak-crx's Avatar
Default Re: (goldegg)
It's on the list.....Check their catalog
Old May 27, 2007 | 07:57 PM
kleen98accord's Avatar
Default Re: (blaak-crx)
sometimes premature wear on bushings is due to import tightening specs. so check much you need to torque those down.
Old May 30, 2007 | 04:13 AM
Kusai.Nihonjin.Desu's Avatar
Default Re:
Polyurethane needs to be lubricated. Upgrade to their rubber bushings kit.
Yours probably wore out prematurely due to no lube. Rubber doesn't need to be lubed, so it'd probably save you in the long run.
chrisbell37
15
Jul 30, 2006 02:40 PM
teg21
Jul 9, 2002 09:46 AM
99ls
Aug 16, 2001 12:55 PM
