Body Work Estimate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaymua »</TD></TR><TR><TD CLASS="quote">i was thinking about cutting and welding a new sheet, and i would paint it mysefl</TD></TR></TABLE>
if you can do it yourself, you will save a TON of money.
if you took it to a shop, yo figure they would either do that, or just replace the entire quarter panel, and then paint it.
i have two shopping cart dents in my rear quarter panel. i went to get an estimate to either get them pulled out, and also to replace the entire quarter panel. i think the guy said around $700-$800 or so (give or take) to replace the panel and paint it.
your best bet will be to just go to several local body shops and get quotes.
thanks...it was either the shop or a buddy of mine said to put cardboard behind the area and use bondo like a million times.. kinda ghetto but if it'll save me hundreds maybe but i doubt i will go with that choice
for the fuel lid I suggest getting a none rusted one from a junk yard. and for the other rust do NOT USE BONDO it will crack and break on you. You're gona have to cut the area out and weld in a new piece this will be your bestest bet.
go yo your local paint store buy some rust killer you can spray it on all the rust and it will stop growing then cut it out a put new metal in DO NOT USE CARDBOARD or any other half *** way of doing it, it will come back and will fight it untill you fix it right
it would be cheaper to buy another rust free teg than to properly repair this rust, I'm 100% positive that this is not the only rust spot,
get a new car with no rust
yea but if he can find the rust throughout the car, a shop can patch it all up with new steel for pretty cheap, or about 500 bucks if u can find it all, it takes a good shop no time to patch rust up.
the shop in ohio i went to charged me 550 to patch up 7 spots on my old 4gen prelude, which was as bad as urs, so just ask around
EF7
Feb 24, 2007 10:40 AM
datssoled
21
Oct 12, 2006 12:26 PM
EJ2_B16
13
Jan 17, 2006 02:59 AM
