b17-b18 help
Old May 27, 2007 | 12:43 AM
da6jdmteg's Avatar
Default b17-b18 help
i was wondering what i needed to do to run b17 in a b18 bottom end. i have a 18 crank and block. everything else is 1.7. how would it work out or would it. i been trying to research this for sometime. im leading to beleive its not possible.i have found nothing. i have the 1.7 rods, pistons oil pump, and pan, the little feeder thing. water pump timing belt, complete b.17 head. 18 crank and block. please tell me if it will work out or if i need to do something else. thanks.
Old May 27, 2007 | 10:26 AM
doood's Avatar
been there done that
Default Re: b17-b18 help (da6jdmteg)
that will not work very well
Old May 27, 2007 | 10:31 AM
nate_2k5's Avatar
Default Re: b17-b18 help (doood)
you need the whole b17 rotating assembly, crank included, all you will do is effectively lower displacement. the b17 uses a b16 head which is the same casting as the itr head but without the goodies, just get b18c rods and itr pistons
Old May 27, 2007 | 10:32 AM
Dartanian's Avatar
B17 rods are too short for a B18 block. If you swap those out, everything should work.
Old Jun 4, 2007 | 07:38 AM
da6jdmteg's Avatar
Default Re: b17-b18 help (Dartanian)
what if i put the 1.7 pistons on the ls rods?
AnointedDC5
May 31, 2010 10:15 AM
crawlin
Aug 5, 2007 08:56 PM
nota-eg
Jun 15, 2006 10:26 AM
BoostedAcura
Sep 22, 2003 06:32 PM
