Sensor help for an H22 swap
Old May 26, 2007 | 09:48 PM
jlhansen's Avatar
Default Sensor help for an H22 swap
As I read somewhere, "Flame Suit on. . ."
The engine is in and running, but the sensor situation is a bust.
Is there anyone on this forum patient enough to provide me with a diagram of the sensor positions and identifications on the H22? I think that, armed with that, I can figure out where on the Accord harness to hook them.
There's plenty of help here in the form of verbage, but the pictures are probably going to be the only solution that will work for me.
The car is a 94 EX and we haven't switched the pins for the ECU yet because there's some question around here on the years that swap applies to. Also, we're running the EX's ECU, but that seems like it would be set up wrong to run an H22. We're running the F22B1 Throttle Body to allow for the MAP sensor and cruise control, but there are so many other H22-specific sensors that I'm not sure I'll ever get it sorted out. It seems so close, but I think it's not.
I'll appreciate anyone who will walk me through this. Rest assured that I've waded through the FAQs ad nauseum and have come out more confused than ever.
TIA,
jeff
Old May 28, 2007 | 06:34 PM
Tnwagn's Avatar
Default Re: Sensor help for an H22 swap (jlhansen)
http://www.cb7tuner.com/vbb/showthread.php?t=5423
That's the best faq I've seen. Not for cd's but it shouldn't be that much different. It covers pretty much every sensor that there is on the h22.
Old May 29, 2007 | 05:17 AM
jlhansen's Avatar
That does look good. I really hope, though, that I don't have to buy a helms to see the in-depth stuff. The engine actually runs well, but the idle surges. I just remembered last night that I had to pull a vacuum tap that was damaged in shipping (rear of manifold plenum) and forgot to plug the hole. I'll have to fix that.
Thanks for the link.
Ocho
Nov 11, 2011 04:05 AM
JasonST
Jan 24, 2006 02:31 AM
95c1v1cs1
May 16, 2003 12:50 PM
nickg11111
Jan 31, 2003 06:55 AM
