hood gas spring conversion
Old May 26, 2007 | 09:29 PM
K I T T's Avatar
Default hood gas spring conversion
Does any body know if the EG hatch spring gas for the rear glass can be used on the hood of a EK?
I looked for gas springs used for rear doors of vans but are too big for the hood.
i would like to do this on my EK...
Old May 26, 2007 | 10:01 PM
Eran's Avatar
HT White Ops
Those aren't springs, they're an oil-filled gas shock. Huge difference.
And no, that's not hard. That's actually a kit you're looking at made by Tein. You cannot do it with a carbon fiber or fiberglass hood, they're too brittle and light.
http://www.tein.com/hooddamp.html
Old May 26, 2007 | 10:09 PM
Eran's Avatar
HT White Ops
Default Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">so where do you go to buy the little "ball" for the ball joint. i remove those from the decklid of the tC's at work and the "ball" is reused. i have tons of those at work and a set on the hatch of my mustang/</TD></TR></TABLE>
It's a kit. It comes with brackets, ball joints, and shocks. I think NRG makes a knockoff ... that unfortunately costs just as much as the Tein one.
Old May 26, 2007 | 10:52 PM
Team RS2's Avatar
its called a heim joint buy a small one, my firend did that, letme guess to help the cf hood stand up straight right? only thing i hate about my cf hood is it straight sags and you can see light through the weave
Old May 26, 2007 | 10:59 PM
Team RS2's Avatar
isnt it reassuring that the strongest body part on your front end was replaced with a fiberglasses skeleton and something that you can see sunlight through? nah i love it man saved at least 20 pounds
Old May 26, 2007 | 11:16 PM
Eran's Avatar
HT White Ops
Don't use these on carbon hoods. I've seen them crack in half from the stress of someone closing it with a damper on it.
Old May 28, 2007 | 03:12 AM
K I T T's Avatar
yes I know there's a specifi kit for it.
but i'm ghetto and would like to try if the EG hatch rear glass stands can hold the weight of my stock hood.
My hood stand just got twisted the other day and there are a lot of surplus from japan sitting around here...
Old May 28, 2007 | 05:32 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (K I T T)
who knows, try it, I'm sure the hatch weighs more than a hood
Old Jun 9, 2007 | 06:40 PM
K I T T's Avatar
ok i was really eager to do this conversion. And so i was successful!
the hatch dampers were long enough to move the hood all the way up, unlike the tein kit which has limited extension. I can open my hood all the way up, and also 3/4 way up.
I used a pair of eg hatch rear glass dampers, fabricated brackets nd bolted everything on.
spent $18 for this mod... :D
Old Jun 10, 2007 | 01:41 AM
K I T T's Avatar
the ball joints at either ends are included in the EG hatch dampers. I just custom fabricated the brackets where the ends bolt right in to.
Old Jun 10, 2007 | 08:42 AM
Hartattack's Avatar
Default Re: (srehtorblos)
Password jdm makes a kit also, you can adjust the valves in them so they'll work with cf hoods. Might be worth checking them out if any of you have cf hoods
Old Jun 10, 2007 | 08:44 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Hartattack)
I think passwords kit is more expensive than the tein kit.
Hiroshima_VTi-S
17
Mar 28, 2007 01:10 AM
keprunited8
Apr 3, 2005 09:51 PM
Jamez
Suspension & Brakes
Feb 12, 2005 01:20 PM
6MTV6
22
Aug 11, 2004 06:04 PM
Pants
Aug 12, 2002 11:19 AM
