Is it worth doing "poor man's ITR" set up on my GSR?
Old Jun 2, 2002 | 10:31 PM
iH8RICERZ's Avatar
Default Is it worth doing "poor man's ITR" set up on my GSR?
I have a 94 GSR w/ 143,xxx. The car still runs strong, but i'm thinking about going another route w/ my all motor set up. As of right now, i have ctr intake cam, cam gears, jdm p30 ecu, I/H/E and no cat! I had a skunk2 IM on the way, but i ended up getting scammed! Question is, if i can get a b16 head for cheap....should i build that head (port n polish head, itr manifold, etc.) and replace my GSR head w/ that? Worth the work and power? anybody else do a b18c block and b16a head swap?
Old Jun 3, 2002 | 07:14 AM
iH8RICERZ's Avatar
Default Re: Is it worth doing "poor man's ITR" set up on my GSR? (BustAhNutZ101)
no replies...???????????? hrmmmm
Old Jun 3, 2002 | 07:29 AM
X2BOARD's Avatar
The B16 head will drop your compression ratio about .2, ie... you will lose some Hp from that.
It is said that the B16 head flows better, but I would reckon they are the almost idential (flow wise) The B16's intake mani is more desirable, but since you can't fit it without cutting, just get a single runner aftermarket. I say build the GSR head instead of busting the mission of the b16, won't be worth it. The only downside to this is downtime.
Old Jun 3, 2002 | 08:34 AM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Yeah, B16 heads are rather quite abundant. You will be able to find them but you will present yourself with a slight drop off in power as mentioned before. If it were me I would just P&P the GSR head and build the Skunk2 IM from a reputable place rather than someone on here.
[Modified by JSM, 11:34 AM 6/3/2002]
Old Jun 3, 2002 | 09:36 AM
Tweakmeister's Avatar
Default Re: Is it worth doing "poor man's ITR" set up on my GSR? (JSM)
What JSM said
Old Jun 3, 2002 | 05:59 PM
Turbo Laser's Avatar
Default Re: Is it worth doing "poor man's ITR" set up on my GSR? (Tweakmeister)
Yep, If you're going to P+P it anyways you don't necessarily have to have a B16...both heade should turn out about equal.
DC2fab
Dec 28, 2024 02:14 PM
Drew17th
Oct 11, 2006 10:18 AM
hialeahzbg
16
Aug 1, 2006 10:57 PM
highrevnef
Apr 2, 2005 01:08 AM
MrSmith
Mar 23, 2002 01:30 PM
