88 hf tranny in a 91 si
Old May 26, 2007 | 08:00 PM
skimb37's Avatar
Default 88 hf tranny in a 91 si
what do i need besides the tranny and engine to put a 91 crx si d16 up to a 88 hf tranny? Which clutch and fly wheel do i need? how many spines?
Old May 26, 2007 | 10:32 PM
Ch3mik's Avatar
Default Re: 88 hf tranny in a 91 si (skimb37)
you will need the clutch and flywheel to match the tranny. why would anyone in their right mind do this anyways? have you seen an 88hf clutch? its like the size of a kids plate at dennys.
Old May 26, 2007 | 10:53 PM
carlthecrx's Avatar
Default Re: 88 hf tranny in a 91 si (Ch3mik)
i have a newer hf, 90-91 i think, if you're interested..
Old May 27, 2007 | 06:09 AM
gibsanez's Avatar
You trying to get mega fuel mileage? If so, good for you, but If you're just looking for a replacement trans than stay the hell away from the HF.
Old May 30, 2007 | 03:24 PM
skimb37's Avatar
Default Re: 88 hf tranny in a 91 si (gibsanez)
yes i am going for mpg. which cv axels do i use. the ones from the si or the hf. the car is a si
Old May 30, 2007 | 03:49 PM
gp70hs's Avatar
You need to use the inner cv from the hf and the outer from the si. I believe you can use an 88 si clutch and clutch plate, to give you more connection. The 88 clutch has a different number of splines on the tranny, but if you use a 88 clutch, you should be fine.
Old May 30, 2007 | 04:29 PM
Angry's Avatar
Default Re: 88 hf tranny in a 91 si (gp70hs)
^^^^....You have it backwards, the outers are the different ones. You can use your Si axles. I know this for a fact, I ran Si knuckles and axles in my 88HF before I swapped out the 8-valve and HF trans. The outer HF CV joints are like tooth picks.
Having the smaller 88HF clucth will allow for a bit better MPG as its lighter.
Old May 30, 2007 | 04:59 PM
skimb37's Avatar
Default Re: 88 hf tranny in a 91 si (Angry)
thanks
slammedz6ef
Nov 24, 2008 05:23 PM
Maireeka
Nov 9, 2008 04:27 PM
white90crxhf
Jan 6, 2006 09:10 AM
The DX Rex
Nov 22, 2005 03:57 PM
airikkCRX
Apr 14, 2004 06:07 PM
