very dumb question but i just thought about it.............
Old May 26, 2007 | 07:50 PM
ericstambaugh07's Avatar
Default very dumb question but i just thought about it.............
i saw the fiberglass cloth that you use for fiberglass work...and i thought isnt header wrap just a thicker fiberglass? would you be able to use the fiberglass cloth on your headers if you can get it thick enough?
Old May 27, 2007 | 08:36 AM
mgags7's Avatar
Just buy the header wrap that is publicly available. I know header wrap has fiberglass in it but I doubt that that is the only "ingredient" lol
On a side note, never let that **** his your forearms , talk about itchy.
Old May 27, 2007 | 03:03 PM
preludefien
Guest
Posts: n/a
Default Re: (mgags7)
i wouldnt use heat wrap. it will eat your header up.
Old May 27, 2007 | 03:07 PM
IIVIIoOkY's Avatar
Default Re: (preludefien)
the only way heat wrap will mess up your header would be if you were dumb enough to have a mild steel header and not sand and paint it due to moisture getting under the heat wrap. then thats your fault even if you have an awesome header...
Old May 27, 2007 | 05:39 PM
mgags7's Avatar
If you let moisture hang around any material long enough, oxidation is going to happen, I don't care what kind of steel your header is made of.
Old May 27, 2007 | 06:06 PM
Hawkze_2.3's Avatar
Default Re: very dumb question but i just thought about it............. (ericstambaugh07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericstambaugh07 &raquo;</TD></TR><TR><TD CLASS="quote">i saw the fiberglass cloth that you use for fiberglass work...and i thought isnt header wrap just a thicker fiberglass? would you be able to use the fiberglass cloth on your headers if you can get it thick enough?</TD></TR></TABLE>
Header wrap is nothing like fiberglass cloth. You have obviously never seen either, but I promise you they are very different.
Old May 27, 2007 | 06:15 PM
cb7tougeracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
On a side note, never let that **** his your forearms , talk about itchy.</TD></TR></TABLE>
i concer with that itch city
Capo dei Capi
Dec 6, 2007 08:06 PM
kornerk12
May 26, 2007 10:10 AM
d16dcoe45
58
Nov 18, 2005 03:47 PM
Catch 22
25
Apr 14, 2003 04:23 PM
