CF USDM 98-01 VIS Front Lip Fitment Off?
Old May 26, 2007 | 04:22 PM
A's 94 GSR's Avatar
BG-33P
Default CF USDM 98-01 VIS Front Lip Fitment Off?
Today I installed my new 98-01 USDM carbon fiber VIS front lip, but the fitment on the sides are off. It seems like it should extend to the end of the bumper more. The package says 98 Integra on it. Any ideas on what to do?
Old May 26, 2007 | 04:54 PM
A's 94 GSR's Avatar
BG-33P
Default Re: CF USDM 98-01 VIS Front Lip Fitment Off? (A's 94 GSR)
Pictures:
Old May 26, 2007 | 09:11 PM
ironcheftony's Avatar
u have to squeeze it on, take off teh bumper and install it off the car, push the bumper sides inward and stretch the lip on , screw the side in at a time, should work like that, most lips in that form have to be put on like that from like knowledge, unless im gettin jacked up lips as well
Old May 28, 2007 | 11:33 AM
A's 94 GSR's Avatar
BG-33P
Default Re: (ironcheftony)
How would I stretch it? Its carbon fiber.
Old May 28, 2007 | 12:09 PM
yee SERIOUS's Avatar
try blow drying. it works for the abs ones. not too sure about the cf ones. but it's worth a try.....
Old May 28, 2007 | 03:28 PM
mugenracer's Avatar
stretch the lip itself slightly and at the same time compress the sides of the bumper to get it on (the lip will stretch a certain amount...i had the same problem), it'll fit neatly once you get it over the bulging outer parts of the bumper (at the very back corners) Like said above its a lot easier to do when you remove the bumper completely.
Old May 28, 2007 | 11:37 PM
2f2fLOL's Avatar
Default Re: (mugenracer)
A lot of the VIS lips are like this. They fit pretty much perfect. We had the same experience trying to put on the VIS spoon replica CF lip onto a EG, but we mananged to get it on with a little patience.
Old May 29, 2007 | 06:02 AM
Arsenal's Avatar
Default Re: (2f2fLOL)
Take it off, use two zipties to hold it in the middle. Then pull the sides around the edge. The zipties will give you a little play for adjustment. Then when the sides are on bolt the middle part back on.
Like others said, take the bumper off, much easier.
If its any help, mine was the same, but with the same method I got it to look like this...even though its a 94-97 and Spoon lip, the idea is still the same.
g3teg97
Apr 17, 2008 04:03 PM
CRX_RUS
26
Jun 24, 2005 07:59 AM
d8168055
Jun 11, 2003 07:17 PM
Hybrid 350GT
May 21, 2003 05:25 AM
Revgasm
Feb 24, 2003 06:01 AM
