Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Wanting to learn about tires and rims.
Old May 26, 2007 | 03:58 PM
05civicdriver's Avatar
Default Wanting to learn about tires and rims.
Hey guys,
I really want to learn about the tires and the rims. my 2005 civic has the stock rims n cheap tires. just wanna know what sizes rims and tires i can fit in my car. I saw this ad for rims 17"x7 rims and bolt pattern is 10x110/114.3. . now i have no clue what dat means at all. If anyone could teach me a bit. thnx!
Old May 26, 2007 | 04:00 PM
sujak's Avatar
17" = Diamter
7" = Width
10x100 means it has 10 lugnuts 1 every 100mm (which is odd... wtf are these rims for a semi?) should have 4-5 max. 4 for a 01-05 civic (non ep3)
Old May 26, 2007 | 04:08 PM
Default Re: (sujak)
i just saw it from an ad. this is what it says. this is the add.
Four Brand new, in the box, 17"x7, Black polished, with chrome lip rims. Bolt pattern is 10x110/114.3.
Should i ask the seller for any other info? like regarding the bold pattern?
Old May 26, 2007 | 04:36 PM
sujak's Avatar
i dont know? i dont care if you do or dont..
you need 4x100
Old May 26, 2007 | 08:28 PM
toyomatt84's Avatar
Sanji
Default Re: (05civicdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 05civicdriver &raquo;</TD></TR><TR><TD CLASS="quote">i just saw it from an ad. this is what it says. this is the add.
Should i ask the seller for any other info? like regarding the bold pattern?</TD></TR></TABLE>
10x100/114.3 means there's two bolt patterns on the wheel. 5x114.3 and 5x100. Neither of which are the bolt pattern you're looking for.
Old May 26, 2007 | 09:28 PM
sujak's Avatar
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
10x100/114.3 means there's two bolt patterns on the wheel. 5x114.3 and 5x100. Neither of which are the bolt pattern you're looking for. </TD></TR></TABLE>
would make sense if they put 5x100/114.3 but i see the 10 now. , i didnt think about that. im use to wheels with the exact amount of holes you needed.
Old May 27, 2007 | 06:06 PM
Default Re: (sujak)
ok cool thnx! now i know about the bolt pattern. anything else i need to know? what about width? what do i need to know about that?
Old May 28, 2007 | 06:44 AM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 05civicdriver &raquo;</TD></TR><TR><TD CLASS="quote">ok cool thnx! now i know about the bolt pattern. anything else i need to know? what about width? what do i need to know about that?</TD></TR></TABLE>
You won't be able to fit anything wider than 8 inches, with a +42 offset, without extensive fender work.
Ideally, you'd want to have something in the 16x7, 17x7 range, with an offset between +38 and +45.
Old May 28, 2007 | 06:54 AM
Whats the offset mean?
Old May 28, 2007 | 07:12 AM
Newborn_'s Avatar
Grace Under Pressure
Here you go bud.
http://www.needforspeed.co.uk/...s.htm
Old May 28, 2007 | 07:18 AM
Default Re: (ONLYuk7thGen)
thnx man!
user 931176363637
May 31, 2007 02:58 PM
sami
Feb 3, 2003 05:15 AM
