weird problems
Old May 26, 2007 | 02:39 PM
innes887's Avatar
Default weird problems
ive had some weird problems in my 89 crx dx. when im over 20 mph and put on my right turn signal the coolant temp gauge bounces up, and the higher the speed the higher it bounces. the right turn signal light on the dash is light up but its very dim. the left signal is fine though. im thinking its a short in the dash assembly. the other problem i have is when im over 40 mph and i let off the gas while its in gear i get a check engine light. when i checked the ecu i got a vss code, 16, and electronic load detector. i fixed the eld with a new under hood fuse box. but could the code still stay on even if i fixed it? also when i get the engine light my car idles at 1500 or so. thanks for the help. by the way its the stock d15b2 motor with the 5spd trans.
Old May 28, 2007 | 12:21 PM
innes887's Avatar
anyone?
crxaddikt
10
Sep 13, 2014 11:47 AM
Y2KGSR
Feb 16, 2009 12:00 PM
Iamcuddles
Dec 22, 2005 08:51 AM
ExodusJKD
Aug 17, 2004 10:44 PM
civicmark
Sep 2, 2002 05:12 PM
