91 civic dx engine swap help
Old May 26, 2007 | 01:02 PM
jorkee's Avatar
Default 91 civic dx engine swap help
So im planning an engine swap for my civic. It will be a soon to be built D16z6 swapped in for my stock D15.
What im worried about most is the ob0 to ob1 conversion.
How difficult is this and what should i watch out for?
Old May 26, 2007 | 02:11 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 91 civic dx engine swap help (jorkee)
DPFI to MPFI conversion
https://honda-tech.com/zerothread/1917897
You'll then need an OBD0-1 ECU harness (rywire, boomslang, etc). A OBD0-1 distributor adaptor. Then you'll need to wire up the wiring for VTEC solenoid and pressure switch. Also need to wire up a 4 wire O2. And extend the wiring for the fan switch from the back of the block to the thermostat housing.
McKinky
16
Dec 6, 2012 01:37 PM
tmaxxkretchy
Sep 8, 2007 10:25 PM
efhatchbackracer
Oct 21, 2005 12:18 AM
bootsz420
Oct 9, 2005 11:56 PM
