tighten ebrake?
Old Jun 2, 2002 | 09:28 PM
12 oz.'s Avatar
Default tighten ebrake?
how do you effectivley tighten the ebrake on 5th gen civics?
Old Jun 2, 2002 | 10:25 PM
confidence's Avatar
Default Re: tighten ebrake? (Boost Friendly)
take off the center arm rest. at the end of your ebrake handel is a silver rectangle that holds the ends of the e-brake cables. behind it is a 1/2" long sylinder with a 10 or 12mm fitting on the end of it. it's facing the same direction as your ebrake handel.
==handel ==---H- <dum asci diagram
the lil "-" after the "H" is what you are looking for. just grab a ratchet and tighten it up and that should do the trick hope that made sence hehe
[Modified by snail, 7:25 AM 6/3/2002]
Old Jun 3, 2002 | 01:55 AM
TurBoXBirD16's Avatar
Default Re: tighten ebrake? (snail)
but when should be enough??
would it break if it's too tight??
Old Jun 3, 2002 | 02:40 AM
civicgsr19's Avatar
if it has drum brakes in the rear it might be even easier than that.....does it? Because if it does ill post how to adjust the rear drums which also directly tightends the e-brake handle.
Old Jun 3, 2002 | 05:23 AM
12 oz.'s Avatar
Default Re: tighten ebrake? (civicgsr19)
Snail thanks for the info.
CivicGSR19--I do have drums which way is better?
Old Apr 24, 2007 | 12:06 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: tighten ebrake? (TurBoXBirD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 &raquo;</TD></TR><TR><TD CLASS="quote">but when should be enough??
Old Apr 24, 2007 | 12:20 PM
pdiggitydogg's Avatar
jesus christ! this is from 2002????
4-6 clicks to full engagement
cables will stretch LONG before they break...
(oh, and the process to tightening, listed above, is incorrect - you need to jack the rear of the car and press the brake pedal several times, BEFORE messing with the nut under the armrest)
b0yg0tskills
Honda Civic (2001 - 2005)
Oct 8, 2009 04:50 PM
TenLarge
14
Jul 9, 2005 05:55 PM
Ecskater1313
Apr 30, 2004 06:39 PM
FourthGenHatch
Apr 3, 2003 01:48 PM
