Need a part number for a plug on a block...
Old May 26, 2007 | 03:45 AM
geebs's Avatar
Default Need a part number for a plug on a block...
im guessing the plug on the right is the same for the left? i dunno... i need some advice..part number.. something...
its an ls block,99 i believe..
Old May 26, 2007 | 09:44 PM
NOFX's Avatar
H-T White Ops
Default Re: Need a part number for a plug on a block... (geebs)
I have a '99 LS here and the one to the right is round while the one to the left is hexigonal or something.
I can't find it in the EPC though.
Old May 26, 2007 | 10:54 PM
Luserkid's Avatar
Default Re: Need a part number for a plug on a block... (NOFX)
Are you talking about the breather holes? You could get another plug or get the fitting from the dealer to have an aftermarket catch can.
Old May 26, 2007 | 11:02 PM
NOFX's Avatar
H-T White Ops
Oh, and I'd take a photo of the plug the one here has... but it's on a car and so I dont' think I could.
Team RS2's Avatar
Default Re: Need a part number for a plug on a block... (Luserkid)
from like an old B20 prelude or something right? or is he talking about one of the FREEZE plugs?
Old May 27, 2007 | 06:55 AM
geebs's Avatar
Default Re: Need a part number for a plug on a block... (Team RS2)
the motor didnt come witha breather chamber... atleast i didnt get one when i picked it up.. and someone told me that he has like a fan switch or temp sensor in the large hole to the left of the oil filter... it has a reducer piece to make it fit.. i dunno.. i couldnt find it on any honda parts page or the epc...
Old May 27, 2007 | 09:49 AM
Luserkid's Avatar
Circle which part your actually looking for and ill get you a part number.
Old May 27, 2007 | 10:40 AM
NOFX's Avatar
H-T White Ops
I managed to get a photo of the plug from the 99 LS I have here.
Sorry it's a crappy pic, but it's tight back there.
Old May 27, 2007 | 11:00 AM
pdiggitydogg's Avatar
This is prelude, however, its the same size
Number 2 are breather vents (you could use those and just cap them) - No. 11107-PK2-003
Number 25 seems to be the proper plug - No. 90001-PM3-003
(I say seems, because the washer for it and the vent are the same, so it has to be the same size...)
Old May 27, 2007 | 11:23 AM
NOFX's Avatar
H-T White Ops
Default Re: (pdiggitydogg)
That was the closest I could find on my initial search the other night when I first saw this thread.
I'm not sure that's right though. I think that's a number for a round plug, not the hexogonal plug that he's looking for.
I even looked through my Civic repair manual PDF (for the B16A2) and though I could see it in images, there was never any information given on it.
Here's the page I was looking at for the '99 LS.
Old May 27, 2007 | 11:31 AM
That vent/breather # I posted is the one that endyn uses (and modifies) for their breather kit.
But like I said, assuming that the plug is the same size as the vent, it should work.
Old May 27, 2007 | 11:45 AM
Team RS2's Avatar
yea i think the b20 prelude one is what he is looking for NOFX the plug in the front of the block looks diffrent than the one he needs
Old May 27, 2007 | 12:04 PM
NOFX's Avatar
H-T White Ops
Default Re: (Team RS2)
The plug he lists up for the B20 as seeming to be the right plug (he lists it as number 25 in his image) is the same exact part number as the part I listed up.
They're the same part.
In fact, here is a photo of the part we were both talking about. Notice it's different. I didn't take the OP's question as being, "What can I plug this with?" as much as "What goes here?"
This is the bolt on the front (P/N: 90001-PM3-003).
Old May 27, 2007 | 08:10 PM
geebs's Avatar
Default Re: (NOFX)
hey for all you saying the plug on the exhaust side of the block.. its not the same thread pitch as the one on the intake side.. i ordered that one thinking its the one i needed, or it would match and it didnt.. doesnt thread in but its the correct diameter..
So this part number 90001-PM3-003 refers to the plug (coolant drain) on the exhaust side.. which isnt the correct one i need sadly..
i wish i could find the part number for the hex plug on the right side of the oil filter but i cant..
[edit]
okay so i used the epc and did a search for all 28mm bolts..
i clicked on the 11106-pr4-013 and it said it was only used in the RSX...
judging from the picture it looks like it has a hex on it.. i dunno.. maybe ill waste another $5 and see if it fits..
Modified by geebs at 12:29 AM 5/28/2007
Old May 28, 2007 | 09:58 AM
Team RS2's Avatar
Default Re: (geebs)
why dont you just return the part and tell em its difrent
Old May 28, 2007 | 10:45 AM
geebs's Avatar
i ordered it online not from a local dealer..
not really worried about it..
Old May 28, 2007 | 10:51 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: (geebs)
It may be a sensor that is used for that hole. Check the pics with the green plug sensor in this link out:
http://www.team-integra.net/fo...age=2
Old May 28, 2007 | 10:54 AM
NOFX's Avatar
H-T White Ops
Default Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">It may be a sensor that is used for that hole. Check the pics with the green plug sensor in this link out:
http://www.team-integra.net/fo...age=2</TD></TR></TABLE>
It's not a sensor.
This is the SAME PART on a stock 1999 LS (same exact motor he has) in a running car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">I managed to get a photo of the plug from the 99 LS I have here.
Old May 28, 2007 | 11:53 AM
geebs's Avatar
Default Re: (NOFX)
it doesnt make any sense...
the picture that your posted NOFX, doesnt have a sensor.. just a plug
but the picture tech8 posted a link to shows a sensor there.. thats how my friends b18a looks.. like a temp sensor or something..
either way tho, i cant find a part number for either through the honda epc or on any of the part web pages...
only thing i found was the coolant drain plug on the exhaust side of the block being a 28mm plug.. diameter wise its correct but thread pitch wise its incorrect.
i dunno.. never had a problem like this.. heh it sucks.
Old May 28, 2007 | 11:55 AM
Team RS2's Avatar
Default Re: (geebs)
just go get a custom plug of go to autozone and ask to see their freeze plug selection they might have it
Old May 28, 2007 | 09:00 PM
NOFX's Avatar
H-T White Ops
Default Re: (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt make any sense...
i dunno.. never had a problem like this.. heh it sucks.</TD></TR></TABLE>
But you don't have a B18A. I can't list all the differences between the B18A and B18B, but apparently that's one of them.
Maybe I'll stop by Honda tomorrow and ask a friend of mine.
Old May 29, 2007 | 05:21 PM
geebs's Avatar
Default Re: (NOFX)
i know i dont have a b18a.. but a plug w/ a sensor will fill the hole i have on my block.. whether i need that sensor or not.. i cant find a part number for the plug, or the plug/reducer/sensor ..
STN_Pat
Feb 25, 2009 07:13 AM
TylerB
13
Apr 23, 2006 03:58 PM
White_EK49
Sep 27, 2005 05:16 PM
TurbothisLS
Sep 22, 2002 11:25 AM
