Need a part number for a plug on a block...
im guessing the plug on the right is the same for the left? i dunno... i need some advice..part number.. something...
its an ls block,99 i believe..
H-T White Ops
Re: Need a part number for a plug on a block... (geebs)
I have a '99 LS here and the one to the right is round while the one to the left is hexigonal or something.
I can't find it in the EPC though.
Re: Need a part number for a plug on a block... (NOFX)
Are you talking about the breather holes? You could get another plug or get the fitting from the dealer to have an aftermarket catch can.
Re: Need a part number for a plug on a block... (Team RS2)
the motor didnt come witha breather chamber... atleast i didnt get one when i picked it up.. and someone told me that he has like a fan switch or temp sensor in the large hole to the left of the oil filter... it has a reducer piece to make it fit.. i dunno.. i couldnt find it on any honda parts page or the epc...
This is prelude, however, its the same size
Number 2 are breather vents (you could use those and just cap them) - No. 11107-PK2-003
Number 25 seems to be the proper plug - No. 90001-PM3-003
(I say seems, because the washer for it and the vent are the same, so it has to be the same size...)
H-T White Ops
Re: (pdiggitydogg)
That was the closest I could find on my initial search the other night when I first saw this thread.
I'm not sure that's right though. I think that's a number for a round plug, not the hexogonal plug that he's looking for.
I even looked through my Civic repair manual PDF (for the B16A2) and though I could see it in images, there was never any information given on it.
Here's the page I was looking at for the '99 LS.
That vent/breather # I posted is the one that endyn uses (and modifies) for their breather kit.
But like I said, assuming that the plug is the same size as the vent, it should work.
H-T White Ops
Re: (Team RS2)
The plug he lists up for the B20 as seeming to be the right plug (he lists it as number 25 in his image) is the same exact part number as the part I listed up.
They're the same part.
In fact, here is a photo of the part we were both talking about. Notice it's different. I didn't take the OP's question as being, "What can I plug this with?" as much as "What goes here?"
This is the bolt on the front (P/N: 90001-PM3-003).
Re: (NOFX)
hey for all you saying the plug on the exhaust side of the block.. its not the same thread pitch as the one on the intake side.. i ordered that one thinking its the one i needed, or it would match and it didnt.. doesnt thread in but its the correct diameter..
So this part number 90001-PM3-003 refers to the plug (coolant drain) on the exhaust side.. which isnt the correct one i need sadly..
i wish i could find the part number for the hex plug on the right side of the oil filter but i cant..
[edit]
okay so i used the epc and did a search for all 28mm bolts..
i clicked on the 11106-pr4-013 and it said it was only used in the RSX...
judging from the picture it looks like it has a hex on it.. i dunno.. maybe ill waste another $5 and see if it fits..
Modified by geebs at 12:29 AM 5/28/2007
[edit]
H-T White Ops
Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 »</TD></TR><TR><TD CLASS="quote">It may be a sensor that is used for that hole. Check the pics with the green plug sensor in this link out:
http://www.team-integra.net/fo...age=2</TD></TR></TABLE>
It's not a sensor.
This is the SAME PART on a stock 1999 LS (same exact motor he has) in a running car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">I managed to get a photo of the plug from the 99 LS I have here.
Sorry it's a crappy pic, but it's tight back there.
It's not a sensor.
Re: (NOFX)
it doesnt make any sense...
the picture that your posted NOFX, doesnt have a sensor.. just a plug
but the picture tech8 posted a link to shows a sensor there.. thats how my friends b18a looks.. like a temp sensor or something..
either way tho, i cant find a part number for either through the honda epc or on any of the part web pages...
only thing i found was the coolant drain plug on the exhaust side of the block being a 28mm plug.. diameter wise its correct but thread pitch wise its incorrect.
i dunno.. never had a problem like this.. heh it sucks.
H-T White Ops
Re: (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs »</TD></TR><TR><TD CLASS="quote">it doesnt make any sense...
i dunno.. never had a problem like this.. heh it sucks.</TD></TR></TABLE>
But you don't have a B18A. I can't list all the differences between the B18A and B18B, but apparently that's one of them.
Maybe I'll stop by Honda tomorrow and ask a friend of mine.
Re: (NOFX)
i know i dont have a b18a.. but a plug w/ a sensor will fill the hole i have on my block.. whether i need that sensor or not.. i cant find a part number for the plug, or the plug/reducer/sensor ..
TurbothisLS
09-22-2002 11:25 AM
