b16 header, helppppppppppppppppp
Old May 26, 2007 | 01:37 AM
4g4db16's Avatar
Default b16 header, helppppppppppppppppp
will a b18 header fit a b16a?, also whats the best vtec controller to buy? im running stock pwo ecu (obd0) thanks alot
Old May 26, 2007 | 08:01 AM
EF_LSVtec's Avatar
Default Re: b16 header, helppppppppppppppppp (4g4db16)
All B series headers/exhaust manifolds are interchangeable...
*why do you need a vtec controller?
Old May 26, 2007 | 08:13 AM
HondaCivicSiR1's Avatar
Default Re: b16 header, helppppppppppppppppp (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">All B series headers/exhaust manifolds are interchangeable...
*why do you need a vtec controller? </TD></TR></TABLE>umm no there not a b16a header will not fit a b18 so you are wrong there.and to answer your question yes you can use a b18 header on a b16.
Old May 26, 2007 | 11:20 AM
4g4db16's Avatar
Default Re: b16 header, helppppppppppppppppp (HondaCivicSiR1)
i want to lower my vtec, its poping at 5000 or 5100 rpms, i want it lower just for the races, why you ask, would something go wrong? so i could use a b18 header on my b16? i want to get a good 4-2-1 for ground clearence, plus with a 4-2-1 i can get the two o2 sensors in the right spot, i hate cels lol, thanks alot guys for the info, if you have anymore get back to me
Old May 26, 2007 | 11:36 AM
.Manny.'s Avatar
Touching My Member
leave it where its at right now. if you dont tune the ecu for the lower vtec engagement, its going to run like ****.
that b16 wont benefit from a vtec controller. but if you eventually want to blow your motor from bed timing and fuel maps, then go for it
Old May 26, 2007 | 11:42 AM
4g4db16's Avatar
Default Re: b16 header, helppppppppppppppppp (.Manny.)
ok thanks, and good looks
Old May 26, 2007 | 11:47 AM
Raptastik87's Avatar
I wouldn't lower the vtec any, 5 grand is a good place to cross into vtec. I switched my vtec to a lower engagement via spoon chip but thats only cause it was kicking in at 5800. Remember, vtec runs off of oil pressure, so when you lower its engagement, it doesn't kick in as strong as it would where its set now beacuse of that, you would just get it a hair earlier, plus buddies of mine with vtec controllers have played around with vtec engagements and their pretty fond of a 5200 crossover and your pretty close to that, ok, thats my 2 cents
Old May 26, 2007 | 04:37 PM
electric_rex's Avatar
Default Re: b16 header, helppppppppppppppppp (Raptastik87)
buy lowering vtec you really screw with the factory design.
the only reason you should lower it is if you are having your car dyno tuned and you map the low and high cams seperately to find the perfect crossover point.
the best vtec crossover is the one you dont feel by letting vtec kick on early you would be robbing yourself of the much needed torque that is found in the lower rpms.
the smaller cam lobes one the camshaft are designed to restrict exhaust flow to increase toque until a cetain rpm where the motor switches to a bigger cam for higher rpm breathing.
lowering the crossover point you will be using the big cam in the lower rpms exactly what its not designed for.
Old May 26, 2007 | 07:24 PM
EF_LSVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">umm no there not a b16a header will not fit a b18 so you are wrong there.and to answer your question yes you can use a b18 header on a b16.</TD></TR></TABLE>
Type R header and B16 header can interchange, and I've used a Type R header on my B18a/b...so why wouldn't a B16 header fit a B18a/b?
Old May 26, 2007 | 10:15 PM
Bob_760's Avatar
B16A has a shorter deck height, all other B-Series blocks are taller. A B16A header will not fit on any other B-Series motor.
crxsi361
Dec 5, 2009 09:14 AM
4g4db16
21
Jul 9, 2007 05:23 PM
STP_crx123
Jan 4, 2006 11:32 AM
punx04
Sep 4, 2005 12:11 PM
honda06si
15
Aug 16, 2004 05:30 PM
