Snapped a waterpump bolt :l
Old May 25, 2007 | 04:29 PM
HBK's Avatar
HBK
Default Snapped a waterpump bolt :l
I'm trying to put my a6/y8 motor together and what do you know? A damn 10mm bolt snaps when I'm torquing down the waterpump. Took the waterpump off, drilled a pilot hole, and bought a 12$ extractor kit......nothing doin.
Can I take the block to NAPA and have them remove the bolt and rethread a new hole? I'm frustrated as hell, but atleast I have a daily to get around and this is just my project.
My options are limited and the beer is running out
Dammit. I tried to do this exact same swap 2 years ago and the same damn bolt snapped on me. I have THE WORST LUCK in life. ask thenick
Old May 25, 2007 | 04:35 PM
jakscivic's Avatar
Im not sure that they will do it for you but then again ive never asked for something like that. They might who knows. You should just aks them, or take it to a shop and have them do it.
It sounds like you dont have a very good TQ wrench. Ive seen TQ wrenches that are set to 20 ft lbs and are actually tqing at 60 ft lbs. I would say get a good TQ wrench for the rest of the build.
Old May 25, 2007 | 05:28 PM
HBK's Avatar
HBK
Default Re: (jakscivic)
Using a craftsmen torque wrench, but the bolt snapped with my gear wrench prior to even torquing it down. I just worded it wrong originally. It didnt even feel tight, otherwise I wouldnt have kept going. I hope they can do something for me, not sure who else around here can do it.
Old May 25, 2007 | 07:12 PM
hates hondatech's Avatar
* B A N N E D *
Default Re: (HBK)
Usually when you torque bolts to specs they do not break you over torqued it and broke it, understand that if it has a gasket and it's aluminum that pump shouldnt be torqued more that 14 ft lbs. If you were local i would of helped you with your removing the broken piece out of the block good luck and use the torque wrench.
Old May 25, 2007 | 08:32 PM
integrawow's Avatar
Snapped bolt = Noooooooooooooooooooooooo
Old May 26, 2007 | 05:31 AM
HBK's Avatar
HBK
Default Re: (hates hondatech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hates hondatech &raquo;</TD></TR><TR><TD CLASS="quote">Usually when you torque bolts to specs they do not break you over torqued it and broke it, understand that if it has a gasket and it's aluminum that pump shouldnt be torqued more that 14 ft lbs. If you were local i would of helped you with your removing the broken piece out of the block good luck and use the torque wrench.</TD></TR></TABLE>
I was using a small ratchet to tighten it up, and I didn't even get to use the torque gun to torque it to 9lbs. I barely put any pressure at all, and then I snapped it. **** happens, but I didn't over torque it.
Any suggestions as far as removing it? I tried drilling a pilot hole and using an extractor kit but that failed. Machine shop? or any other tricks here?
Old May 26, 2007 | 07:21 AM
~sp33~'s Avatar
EFB055
We should start a "Bolt snapping crew". And i know what you mean about it not tightening and then just snapping off, has happened to me twice.
Old May 26, 2007 | 09:14 AM
sneakerfern's Avatar
Default Re: (HBK)
hit up a machine shop ! ur best bet good luck!
Old Jun 1, 2007 | 01:49 PM
* B A N N E D *
Default Re: (sneakerfern)
Drilling right in the middle of the bolt and using an extractor should have worked. I know thats what i do at work when theres broken manifold bolts to the head.
Old Jun 1, 2007 | 03:18 PM
slaminsam's Avatar
broken bolts really suck!!! take a drill bit that fits in the other holes and drill it the rest of the way out and then re-tap it. just make sure you drill it in the center and straightand dont be stingey with the wd-40 when drilling. it shouldnt be that hard since the motor is out of the car right? a good tap and dye set is worth its weight in gold!!!
Old Jun 1, 2007 | 03:36 PM
HBK's Avatar
HBK
Default Re: (slaminsam)
Well I dropped the block off to NAPA on tuesday and got it back wednesday. The guy used a heli coil, and said the reason it didn't come out my way was because the hole was a little off center. I must have rushed into it and messed it up. BUT, its all set so back to building it I go! I should be updating my build thread soon. thanks for the replies turkies!
Old Jun 1, 2007 | 04:07 PM
* B A N N E D *
Default Re: (HBK)
thats what i thought they would do at a place like that a HEELY COIL. Either way it's fixed.
I like my R
Aug 24, 2023 08:56 PM
DCRB
13
Mar 23, 2010 09:47 AM
hondacivic_si
26
Sep 4, 2004 07:28 PM
.M.
Mar 29, 2004 10:48 AM
is3oo
Oct 4, 2003 01:48 PM
