Crank Pulley on a d15
Old May 25, 2007 | 04:20 PM
Boosted_CRX_507's Avatar
Default Crank Pulley on a d15
so i changed my water pump right and now i have to replace the timing belt...Does anyone know how to remove the crank pulley????
Old May 25, 2007 | 04:47 PM
obd1_crx's Avatar
use an impact gun to remove it. it comes out just like any other bolt. should be a 17mm
Old May 25, 2007 | 04:53 PM
jakscivic's Avatar
yeah its a 17. One way to get it off if you dont have an impact gun is to take the protective plate that covers the flywheel and get pry bar and wedge it in the teeth and have a 1/2 inch 17 along with a long extention connected to your 1/2 wratchet. You may need a cheater bar on it. Thats a long pipe slid over the wratchet handle. It takes a bit of elbow grease to get it off. And maybe a few cuss words.
Old Jun 2, 2007 | 11:23 AM
Default Re: (jakscivic)
man...i tried using an impact gun and having the car in 5th gear with the brakes locked up...it doenst move it at all...and i used 2 different impacts
Old Jun 2, 2007 | 11:36 AM
jakscivic's Avatar
yeah, sometimes the impact guns just dont cut it. I used a 3/4 inch impact gun (which is ****** massive) and it still didnt bust one loose. We had to get a 5 foot cheater bar on a 1/2 inch ratchet to bust it loose. But your going to need a pry bar that wont move at all wedged in the flywheel.
Old Jun 2, 2007 | 11:43 AM
thanks for the help but i already said f it
droppin an ls in...im gonna try and go ls/vtec
Modified by Boosted_CRX_507 at 4:01 PM 6/2/2007
Old Jun 2, 2007 | 01:47 PM
jakscivic's Avatar
nice you will like the lsvtec. I got one in my civic right now and it will soon be swapped over to my crx hf.
Old Jun 2, 2007 | 10:08 PM
low91rex's Avatar
Default Re: (Boosted_CRX_507)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_CRX_507 &raquo;</TD></TR><TR><TD CLASS="quote">****
Modified by Boosted_CRX_507 at 4:01 PM 6/2/2007</TD></TR></TABLE>
Hold on, Your putting a whole new motor in because you cant get the crank bolt off?
Old Jun 2, 2007 | 10:12 PM
minime-civic's Avatar
* B A N N E D *
get a ****** snap on impact, and a craftsman air compressor, with a craftsman air hose, oil the gun and try that... because it all depends on the impact, the hose and thje compressor
Old Jun 2, 2007 | 11:09 PM
jakscivic's Avatar
ok tuff guy, I used my snap on impact and that **** just doesnt come off sometimes. Impact guns are nice sometimes but they dont always get the job done. Like I said before I didnt just use a 1/2 inch impact gun, I used a ****** 3/4 inch impact gun. That is like ****** heavy duty impact gun for high torque and trucks, i could barely hold on to the damn thing. It was turning my wrist. But the damn bolt wouldnt come off. We had to literally get a 5 foot cheater bar and hang on it for it to break loose.
A cheater bar on a 1/2 inch will get you so much leverage. That **** will come right off.
projectjazzmine
Jan 20, 2007 08:55 PM
f150harleytruck7
10
Dec 20, 2005 08:09 AM
Draggin99Si
59
Feb 20, 2005 11:59 AM
MCP486
Apr 1, 2003 09:48 AM
Lei Siew Long
Sep 11, 2001 11:39 AM
