low compression help maybe timing??
Old May 25, 2007 | 03:15 PM
Samuels's Avatar
Default low compression help maybe timing??
Ok my boy hit a hard bump in his LS turbo the motor is completely built and it shut off and tries very weakly to turn over.. Compression is 35 in every cylinder what could be the culprit??
i'm thinking it jumped timing any other ideas?
Old May 25, 2007 | 04:34 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: low compression help maybe timing?? (Samuels)
timing, ringlands .... it could be a few things, have you done a leak down? check it out
Old May 26, 2007 | 08:34 PM
base-op.1320's Avatar
Default Re: low compression help maybe timing?? (Throwdown)
Sounds like to me that your timing is off and your intake valves are open for most of your compression stroke
Scrapin4DR
May 5, 2008 06:33 PM
S@nt0s
36
Oct 14, 2005 07:02 PM
