tires
it depends on how far off your camber and toe is. just get the camber kit and do it all at one time. they are not too expensive. your tire wear should not be too bad though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM100Si »</TD></TR><TR><TD CLASS="quote">you dont need a camber kit. go get an alignment afterwards.</TD></TR></TABLE>
well yeah if you like to burn through tires. i use to burn through tires real quick and barely use to drive my old civic. it's just cheap insurance to get the most wear out your tires. unless you got money to waste on tires all the time. but some people do get lucky without it. like i said above depends on how low you go.
