'99 civic starts then dies
Old May 25, 2007 | 12:09 PM
twocars's Avatar
Default '99 civic starts then dies
'99 civic with AT, 99K
I drive the car long enough to warm it up, turn it off for a while, and when I drive again the car will die. It will start, then die again. This goes on for maybe 5 tries or if I let it sit for a few minutes. Then it runs normal.
1) It's not showing anything as far as CEL codes.
2) I can hear the fuel pump is coming on as normal.
3) I replaced the main fuel relay. I understand there is a problem with the solder connections being exposed to hot temperatures like a closed up car. I know someone who had the same problem and changing the relay fixed theirs, but not mine.
4) Battery connections are clean and tight.
Any help appreciated, thanks
Old May 25, 2007 | 07:27 PM
eskimo10's Avatar
Check your alternator, could be going bad.
Old May 25, 2007 | 07:43 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (eskimo10)
Alternator, or maybe your starter is taking a poop.
A ground could be loose too, but it's unlikely.
Old May 25, 2007 | 08:11 PM
4drcivicls's Avatar
Default Re: '99 civic starts then dies (twocars)
possible crack in your distibuter cap??
Old May 25, 2007 | 08:39 PM
dtapia's Avatar
Default Re: '99 civic starts then dies (4drcivicls)
sounds like a igniter or coil ? it will restart after it cools down ? whats the inside of the dist cap look like any white death present ?
Old May 26, 2007 | 11:51 AM
Frost7177's Avatar
Check your map sensor on the throttle body that the plug is nice and tight.
hypnolobster
Sep 7, 2013 07:21 PM
DZO
May 27, 2012 04:25 PM
cerpher
10
Feb 1, 2006 04:29 PM
bogus_ek
Apr 27, 2005 05:47 PM
bQQsted hybrid
Jun 16, 2003 04:27 AM
