Tranny Fluid Leaking
Old May 25, 2007 | 10:10 AM
Linh.'s Avatar
Default Tranny Fluid Leaking
Today, I went to put in my driveshaftshop axles had a hard time getting it in. So I tapped it in with the a hammer. Then tried to fill the tranny up with fluid it started to leaking at the bottom where the axle was at. I think that my axle isn't far enough in. My question is should I try tapping it in more because it doesnt seem like its sitting in flush enough. Or is my seal bad?
Leaking here
Old May 25, 2007 | 10:39 AM
117's Avatar
117
The driveshaft is not fully seated. I'd remove the driveshaft, ensure that there is no damage to the splines, then attempt to reinstall. You should not have to beat on it to get the driveshaft installed. If you do, there's a problem.
Old May 25, 2007 | 10:42 AM
Linh.'s Avatar
Default Re: (117)
I didnt beat it in I tapped it with a mallet. Everytime I tried to install it once it went half way in it wouldnt go any further.
Old May 25, 2007 | 10:45 AM
117's Avatar
117
Tapped it in with a mallet? Where did you tap it? I usually just swing the knuckle out a bit and give it a tap with the knuckle (with the driveshaft in the knuckle itself), and they usually slide right in. I've done more transmission and driveshaft work than I care to remember, and I haven't had any issues yet. Well, one issue, and that was with an OBX LSD in a Civic, but that was due to the LSD, not the driveshaft.
Old May 25, 2007 | 10:48 AM
Linh.'s Avatar
Default Re: (117)
I put a piece a wood at the end and started to tapped it with a mallet. Im gonna go take it out again. And try to reinstall it.
Old May 25, 2007 | 11:06 AM
117's Avatar
117
Be careful, tapping it on the end with the boot could cause the boot to rip.
Old May 25, 2007 | 11:07 AM
Linh.'s Avatar
Default Re: (117)
Not on the boot but at the end where the nut is suppose to go. Ill let you know how it goes..
shadohconspiracy
13
Nov 4, 2007 08:32 AM
95redeg6
Aug 24, 2006 09:55 PM
97Alex
Mar 20, 2005 02:36 PM
Layziebtnh055
Apr 27, 2004 11:27 PM
DEVIN22CBR
Nov 22, 2003 07:58 AM
