help REMOVING ALT. in CRX b18a1
Old May 25, 2007 | 09:02 AM
rewerbcrx's Avatar
Default help REMOVING ALT. in CRX b18a1
really really need help removing alt.. on a 91 crx with b18a1...
i have been trying for a couple hours... maybe someone has a little trick or a easy way to do this... the only way i see is remove the MC res. and go from there...
HELP HELP HELP i am only home on weekends from working and all i wanna do is drive this thing...
Old May 25, 2007 | 09:06 AM
rewerbcrx's Avatar
Default Re: help REMOVING ALT. in CRX b18a1 (rewerbcrx)
sorry dead thread....
REMOVING THE AXLE... but the question is do i need to replace anything if i remove the drivers side axle?
Modified by rewerbcrx at 1:55 PM 5/25/2007
Old May 25, 2007 | 10:27 AM
D16Z6racing's Avatar
I removed the MC once...then had to buy a new MC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">but the question is do i need to replace anything if i remove the drivers side axle?</TD></TR></TABLE>
Nope. Drop the axel, drop the alt., replace alt., reinstall axel. I had to do this on a friends CRX a few months ago. No problems with it since.
Old May 25, 2007 | 10:51 AM
ludesrv's Avatar
Driver side axle is by far the easiest way in my opinion. I got it down to 45 minutes from start to finish.
Be careful when removing the axle, only time anything can go wrong is if you pull the axle apart by accident.
Old May 25, 2007 | 11:26 AM
rewerbcrx's Avatar
Default Re: (ludesrv)
you mean seperating the boot and everything right?
Old May 25, 2007 | 11:37 AM
mahatma's Avatar
Default Re: (rewerbcrx)
i would replace that axle seal since you're in there anyway
GSR_hatch936
Aug 22, 2007 08:12 AM
Gunmetal_B20_Hatch
Aug 6, 2005 10:16 AM
kefka
Jul 16, 2004 03:34 PM
Red_Si
Sep 23, 2003 04:03 PM
joy-Ride
Jul 25, 2002 01:23 PM
