Honda S2000 Honda S2000
Is my top all the way down ???
Old May 25, 2007 | 08:29 AM
dc-lefty's Avatar
Default Is my top all the way down ???
Just got my soft top replaced under warranty a few weeks ago. First time dropping it yesterday. Do i need to break it in or something ? otherwise its going back in...
Old May 25, 2007 | 08:31 AM
yuedarklord's Avatar
yep its down all the way.
Old May 25, 2007 | 08:38 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Is my top all the way down ??? (dc-lefty)
Yea you need a little adjustment there buddy. They might have goofed the 2 side straps.
Old May 25, 2007 | 08:59 AM
dc-lefty's Avatar
Default Re: Is my top all the way down ??? (Mr. Projekt)
can i adjust it myself ? where are the side straps ?
Old May 25, 2007 | 09:09 AM
* B A N N E D *
Yea, but you'd still have to take apart your interior to get to the other end of it.
That bar that's rubbing on your roll hoops, I believe there's a strap on each side of it, about 1" wide, just below the bend. They should have been fastened to one of the nuts that hold the rear edge of your top down.
Old May 25, 2007 | 09:25 AM
dc-lefty's Avatar
FACK ! back to the dealer it goes... Thanks Projekt !
Old May 25, 2007 | 12:49 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
as you put the top down just push back on that bar and it will pull the top back and will go all the way down! it will keep the top from getting pinched
Old May 25, 2007 | 05:26 PM
MidwestAutoWorks's Avatar
Default Re: (yuedarklord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yuedarklord &raquo;</TD></TR><TR><TD CLASS="quote">yep its down all the way.</TD></TR></TABLE>
Not even close, you have about 2-3 more inches to go
Old May 25, 2007 | 06:27 PM
IntegraLs94Cam's Avatar
my s2k and every other s2k i have seen go down that far
Old May 25, 2007 | 07:10 PM
* B A N N E D *
Default Re: Is my top all the way down ??? (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">as you put the top down just push back on that bar and it will pull the top back and will go all the way down! it will keep the top from getting pinched</TD></TR></TABLE>
That's only on the 00-01s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">my s2k and every other s2k i have seen go down that far</TD></TR></TABLE>
You've seen quite a few mis-adjusted softtops then.
Old May 25, 2007 | 08:00 PM
Rtzx9r's Avatar
GDD 1%
This is my 04, tonight in the garage. no work from the factory, all original.
Old May 25, 2007 | 08:21 PM
Shy_GuyAP1's Avatar
That's the same problem I had, the bar going across the top that is sticking up right by the roll bars isn't folding into place.
When you are putting your top down, there are three canvas supports going across the top, you need to either move the middle forward or backward, you'll figure it out, and it will fold nicely into place.
2000-01?
Old May 25, 2007 | 08:34 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
is there any other kind???
MelJ
Suspension & Brakes
Nov 7, 2010 11:48 AM
vega_ROCKS
Aug 22, 2006 05:54 PM
illusion
Mar 10, 2003 11:43 AM
pr0jektdc2
Mar 9, 2003 10:27 PM
ywwong
Aug 6, 2001 06:32 AM
