need help dohc zc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">D16A1, 89 Integra
(punctuation is a helper
)</TD></TR></TABLE> I think you can you use 88 as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">86-89 Integra D16A1 - LS, RS, GS all have the same engine</TD></TR></TABLE> so the only difference in brown vs. black is the specs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote"> so the only difference in brown vs. black is the specs?</TD></TR></TABLE>main differences between the 86-87 brown and 88-89 black are:
86-87 has different pistons with lower compression ratio, bigger rods, different camshafts, different intake manifold and throttle body, and has vacuum advance ignition
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">main differences between the 86-87 brown and 88-89 black are:
86-87 has different pistons with lower compression ratio, bigger rods, different camshafts, different intake manifold and throttle body, and has vacuum advance ignition</TD></TR></TABLE>very nice...good info
beatthisspeed69
May 16, 2006 09:54 AM
crxzcracer
Jun 17, 2005 09:23 PM
