Is 93 good for 12.5:1 compression?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry »</TD></TR><TR><TD CLASS="quote">you can run that much compression but you wont be able to run very much ignition timing. i would go a little lower and keep your timing up.</TD></TR></TABLE>
That statement is only true when using a small cam.
I am running 35 degrees of timing at WOT on 12:1 with Pro3's. I am not limited on my timing numbers by knock, but rather I stop making power at 36deg. Whereas, when I was running ITR cams, I couldn't push more than 18deg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">That statement is only true when using a small cam.
I am running 35 degrees of timing at WOT on 12:1 with Pro3's. I am not limited on my timing numbers by knock, but rather I stop making power at 36deg. Whereas, when I was running ITR cams, I couldn't push more than 18deg.</TD></TR></TABLE>
good ole dynamic compression
Yep, I have no issues at all. I run low timing on the small lobe but have no problems at all up top once it crosses over. It's very streetable and has plenty of low end even with conservative timing.
Sure can, we have put together a few in your area. Are you going an all oem build, or aftermarket? I take it you are considering 12.5:1 shelf pistons? Contact me if you need any help. I have an all-motor 2000 hatch I'm putting together right now.
Rob
Rob
Hey h customs, if you can give me a call at 337-884-6271. My name is brandon, thanks bro. Oh and by the way, what are the best cams yall think i should use? OEM ITR's or CTR's or something bigger? With bigger cams, will i have piston to valve clearence issues?
HondaHeddie
Dec 17, 2006 04:47 PM
X2BOARD
10
Apr 8, 2004 05:18 AM
