negative rear camber
Old May 24, 2007 | 09:14 PM
redwards's Avatar
Default negative rear camber
ok i got my suspension remounted and i know im gonna hava problem with negative camber cause i used the same springs. in the faq i read about using longer bolts and washers to correct, can anyone give me more information, my springs are neuspeed race springs 2.25in up front and 2in out back, i only have negative camberin the rear. the information i need is the length of bolt and size and also washer size..or whatever.
if anyone has anymore info it would be great.
Old May 24, 2007 | 09:41 PM
ian1006's Avatar
password jdm sells the omni power kit for like twenty bucks. or take a bolt down to the store and get the right size...make sure its grade 8 though and some washers. btw negative damber doesnt matter too much, just set the toe at 0
Old May 24, 2007 | 11:11 PM
garageEF's Avatar
Default Re: (ian1006)
^x2.... negative rear camber wont affect tire wear as long as your alignment is good
jena_blondie
Nov 12, 2009 08:33 PM
Bro. Darkness
Suspension & Brakes
11
Jan 31, 2008 07:32 AM
GreenMachineRex
May 17, 2005 05:58 PM
akeldama
13
Dec 21, 2002 08:39 PM
FourthGenHatch
11
Oct 1, 2002 07:00 PM
